Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
sportlicherFahrer |
Mar 2 2022, 09:19 AM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
@Van B The II is where its at. Part# 91847V. Ran with FI and carbs with 0 issues. Have also run it in conjunction with MSD on my carb setup with good results for a multi spark system. Not sure how MSD runs with original injection.
I'd try to return the III and swap it for a II if you can. |
Lo-Fi Version | Time is now: 16th May 2024 - 10:06 PM |
