Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
r_towle |
Mar 21 2023, 10:16 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I’ve honestly only had one bad round using points and it was the point wearing the rub block down.
They seem to be better now, Bosch only I keep a few sets in the glovebox The setting (fast) is a book of matches slid in. Clean properly lubed distributor is key. Carbs….must be super clean and I’m not a fan with todays ethanol fuels. I would suggest maybe you look into the crank position sensor that goes behind the fan, then a modern multi spark control unit…MSD or other. Rich |
Lo-Fi Version | Time is now: 18th May 2024 - 03:07 AM |
