Distributors and Trigger Points (New Dizzy Installed), Troubleshooting Parts - CHT appears bad |
tvdinnerbythepool |
Sep 9 2021, 08:43 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey all,
I am still chasing down an intermittent RICH condition when the car is fully warmed up. 1.7L D-Jet After fully warmed up with a tuned and rebuilt MPS I can come to a stop light and idle steady at 850rpms, next stop light it's bogging down to almost 200-300 and barely running. Then next light it's idling normally again. Some days I have no issues with idle at all, others I do. I've gone through all the components and troubleshot my way through everything on the PBANDERS list of "my car is running rich". I am as confident as I can be through extensive troubleshooting and testing that my ECU, AAR, MPS, CSV, Vacuum Leaks, CHT, Injectors, Fuel Pressure etc are all good. All new wiring harnesses, plugs, plug wires, cap, rotor, coil, etc. The ONLY thing I haven't worked on is the distributor. I am reading up on the possibility of the Trigger Sensor Contacts being warn and bouncing possibly shooting off extra injection pulses...could this be the cause of the intermittent problem? It doesn't have points anymore, but a petronix I believe. What do you guys think? Is there an easy test for this or do I replace the trigger contacts or the whole dizzy? Cheers! (IMG:style_emoticons/default/beerchug.gif) |
Rand |
Sep 13 2021, 10:09 PM
MPS wouldn't likely be intermittent like that. ECU is usually fail or not, can't see how that would randomly affect idle RPM.
I'd bet it's sticky advance plates in the distributor. Clean and grease. They need to be able to easily move with centrifugal force. Be careful to keep the braided ground wire intact. A 123 distributor would be a huge upgrade for you. |
rjames |
Sep 15 2021, 07:33 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
MPS wouldn't likely be intermittent like that. ECU is usually fail or not, can't see how that would randomly affect idle RPM. I'd bet it's sticky advance plates in the distributor. Clean and grease. They need to be able to easily move with centrifugal force. Be careful to keep the braided ground wire intact. A 123 distributor would be a huge upgrade for you. @rand Agree. Was not suggesting the problem was the MPS but was just pointing out that if would be hard to tune the MPS if their were issues elsewhere (like intermittently running rich). Another vote for the 123 distributor. I replaced a stock distributer that was in good shape and still noticed a big improvement. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:02 AM |
