| tvdinnerbythepool |
Sep 9 2021, 08:43 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest
Hey all,
I am still chasing down an intermittent RICH condition when the car is fully warmed up. 1.7L D-Jet After fully warmed up with a tuned and rebuilt MPS I can come to a stop light and idle steady at 850rpms, next stop light it's bogging down to almost 200-300 and barely running. Then next light it's idling normally again. Some days I have no issues with idle at all, others I do. I've gone through all the components and troubleshot my way through everything on the PBANDERS list of "my car is running rich". I am as confident as I can be through extensive troubleshooting and testing that my ECU, AAR, MPS, CSV, Vacuum Leaks, CHT, Injectors, Fuel Pressure etc are all good. All new wiring harnesses, plugs, plug wires, cap, rotor, coil, etc. The ONLY thing I haven't worked on is the distributor. I am reading up on the possibility of the Trigger Sensor Contacts being warn and bouncing possibly shooting off extra injection pulses...could this be the cause of the intermittent problem? It doesn't have points anymore, but a petronix I believe. What do you guys think? Is there an easy test for this or do I replace the trigger contacts or the whole dizzy? Cheers! (IMG:style_emoticons/default/beerchug.gif) |
tvdinnerbythepool Distributors and Trigger Points (New Dizzy Installed) Sep 9 2021, 08:43 AM
yellowporky Did you resolve this?
You don’t mention the TPS?... Sep 13 2021, 11:35 AM
r_towle Remove, clean and regrease the distributor advance... Sep 13 2021, 05:34 PM
rjames
How did you tune the rebuild MPS? Typically afte... Sep 13 2021, 09:37 PM
Rand MPS wouldn't likely be intermittent like that.... Sep 13 2021, 10:09 PM
rjames
MPS wouldn't likely be intermittent like that... Sep 15 2021, 07:33 PM
Arno914 I have the same issue with my 71-4.
Checked every... Sep 14 2021, 01:57 AM
tvdinnerbythepool Hey guys!
Thanks for everyone's response.... Sep 14 2021, 07:45 AM
tvdinnerbythepool Shaft crud upon removal Sep 14 2021, 07:45 AM
tvdinnerbythepool Clean baby! Sep 14 2021, 07:46 AM
914_teener That dizzy is worn.
Look at the plate on the trig... Sep 14 2021, 10:02 AM
tvdinnerbythepool @914_teener
I take it you are referring to the ci... Sep 14 2021, 03:20 PM
914_teener What do you think? That's normal?
So you thi... Sep 14 2021, 04:13 PM
tvdinnerbythepool I didn't think it was necessarily normal, but ... Sep 14 2021, 04:29 PM
914_teener
I didn't think it was necessarily normal, but... Sep 14 2021, 04:40 PM
Jett We recently sent our distributor out for rebuildâ€... Sep 14 2021, 05:44 PM
tvdinnerbythepool @jett thanks for the info and link
[b]@[url=htt... Sep 14 2021, 08:56 PM
r_towle So, does the odd idle condition still happen?
Adva... Sep 14 2021, 09:03 PM
tvdinnerbythepool @r_towle will try and fire it up tomorrow. Only h... Sep 14 2021, 09:15 PM
tvdinnerbythepool @r_towle will try and fire it up tomorrow. Only h... Sep 14 2021, 09:18 PM
r_towle It’s the advance plates that the points mount to... Sep 14 2021, 11:06 PM
tvdinnerbythepool Agreed, that grease hadn't been grease for a w... Sep 15 2021, 08:28 AM
Solocholo
It’s the advance plates that the points mount t... Sep 21 2021, 12:45 PM
Solocholo
It’s the advance plates that the points mount ... Sep 21 2021, 12:46 PM
Solocholo
It’s the advance plates that the points mount ... Sep 21 2021, 12:47 PM
Solocholo
[quote name='Solocholo' post='2947227' date='Sep ... Sep 21 2021, 12:48 PM
tvdinnerbythepool @Solocholo Dang! At least we aren't the o... Sep 22 2021, 06:30 PM
tvdinnerbythepool Ok guys, I bought the 123 Dizzy, Bluetooth and all... Sep 22 2021, 06:33 PM
bobboinski Black advance Green retard Sep 22 2021, 07:57 PM
tvdinnerbythepool @bobboinski thx! Sep 23 2021, 08:29 AM
tvdinnerbythepool @Solocholo it looks like the contacts for your FI... Sep 23 2021, 08:42 AM
nordfisch Hi to all,
the 123 has a big disadvantage you shou... Sep 26 2021, 02:34 AM
emerygt350 Hmmm, I read that the original design set the inje... Sep 26 2021, 05:21 AM
tvdinnerbythepool Got the distributor installed, I opted for the Blu... Sep 27 2021, 04:10 PM
emerygt350 Nothing you can download from the website?
Really... Sep 27 2021, 05:30 PM
bobboinski Does this help? Around post #102 #132.
http://www... Sep 27 2021, 06:55 PM
tvdinnerbythepool Hey Guys, Thanks for the response.
Long story shor... Sep 27 2021, 08:49 PM
r_towle Here is how I would troubleshoot this.
1) put orig... Sep 27 2021, 09:08 PM
r_towle If all those tests pass, you have and air leak or ... Sep 27 2021, 09:12 PM
JamesM
If all those tests pass, you have and air leak or... Sep 27 2021, 10:57 PM
emerygt350 All great suggestions, and I would start with the ... Sep 28 2021, 05:41 AM
tvdinnerbythepool Thanks all.
I've made a list with the above an... Sep 28 2021, 09:26 AM
tvdinnerbythepool CHT cold (63 degrees F) 49.5K ohms
Well...there... Sep 29 2021, 11:31 AM
tvdinnerbythepool What are peoples experiences between the URO (part... Sep 29 2021, 11:56 AM
emerygt350 I would start with that blow by (compression test)... Sep 29 2021, 01:15 PM
tvdinnerbythepool Update below
CHT: measured 49.7K Ohms at 63 degre... Sep 30 2021, 03:00 PM
DRPHIL914
Update below
CHT: measured 49.7K Ohms at 63 degr... Oct 1 2021, 11:10 AM
emerygt350 The engine is designed with particular vacuum leak... Oct 1 2021, 07:44 AM
tvdinnerbythepool @emerygt350 idle screw does work and is very effe... Oct 1 2021, 12:28 PM
emerygt350 If the idle screw works can you bring the idle up ... Oct 1 2021, 03:44 PM
tvdinnerbythepool
If the idle screw works can you bring the idle up... Oct 1 2021, 09:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:03 AM |
