Brake System leaking at reservoir |
RiqueMar |
Sep 12 2021, 06:03 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi All - Sunday afternoon project and I was preparing to bleed my brakes as seen in the Ian Karr video. All going well, got up to about 1.5-2 lbs of pressure, when I realized my system was 'leaking' from the cloth connectors that link the reservoir to the plastic lines.
Pretty sure I had the bleed-screws open, and it was relatively low-pressure, anyone hav e an experience like this previously? |
RiqueMar |
Sep 12 2021, 07:51 PM
Answering my own question, and as a warning to all those approaching this project. I drained the reservoir using a type of Turkey baster, and then removed it to check the 'cloth' lines. Replaced them with 8mm hose, only to find that I have a very small leak right above the strap that holds the reservoir.
Moral of the story, check the plastic lines, all your connections and the integrity of your reservoir. Special shout-out to the guru, @bdstone914 for letting me bounce some questions off him when I noticed brake fluid dripping out below my steering rack. |
iankarr |
Sep 13 2021, 07:15 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Glad the video helped...and that you got the leak sorted before you got on the road. Assume you replaced with the brake fluid-safe lines. They're usually blue...
brant |
Sep 13 2021, 09:48 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I had the same leak from my reservoir a couple of years ago
I'd recommend you pull the pedal board and look under it. when my reservoir leaked, it ran down the seam on the inside fender well, where it connects to the floor board behind the pedals. I had dripping brake fluid on my skid pan but also found a pool near the pedals... that had seeped through that spot welded seam into the interior compartment under the wooden pedal board. |
RiqueMar |
Sep 13 2021, 12:28 PM
Glad the video helped...and that you got the leak sorted before you got on the road. Assume you replaced with the brake fluid-safe lines. They're usually blue... @iankarr - SeƱor Ian, thanks not only for the video but for your input. The video gives one a great 'baseline', especially if the viewer isn't/wasn't familiar with the power bleeder. Brake fluid lines replaced, simple enough, though now I need a new reservoir. For the record, when draining the reservoir, I used your syringe method and it worked well enough to get 90% of the fluid out. Thanks for the helpful tip. I had the same leak from my reservoir a couple of years ago I'd recommend you pull the pedal board and look under it. when my reservoir leaked, it ran down the seam on the inside fender well, where it connects to the floor board behind the pedals. I had dripping brake fluid on my skid pan but also found a pool near the pedals... that had seeped through that spot welded seam into the interior compartment under the wooden pedal board. @brant - This is very-helpful, thanks. Mine did the same, exited out the drain for the fresh-air blower on the bottom of the gas-tank area and pooled just below the car. I didn't think about the space behind the pedals and I'll check there this evening. Did you have any trouble with your wiring harness after? I just installed the tank and put 8-or-so gallons in, and would hate to have to unwrap the harness. |
brant |
Sep 13 2021, 01:07 PM
I didn't... but it is my race car that no longer has any of the stock wiring
(very few wires total and none in that location) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 PM |
