Pic request 914-6 conversion using CIS throttle, Thought I saved one from a past search - can't find it |
nditiz1 |
Sep 15 2021, 06:49 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I will be using the patrick motorsports linkage and I am already seeing an issue. The sheet metal from restoration design looks to be using the stock location for carbs which pushes the throttle closer to the center of the engine and has the ball on the inside. CIS throttle has it on the outside. I believe some needed to drill out the ball and tap it on the opposite side. Did they also need to drill a new hole? Did anyone get it working with less effort? Maybe just drill a hole further towards the outside of the engine and not mess with the ball on the throttle shaft. Show me what you did if you can, I'm a visual learner (IMG:style_emoticons/default/beer3.gif)
Thanks all! |
nditiz1 |
Sep 15 2021, 10:48 AM
Thanks @SirAndy
@VegasRacer - John did you drill a new hole? Looks like everything is stock. Did you use the existing hole or drill a new one? |
VegasRacer |
Sep 15 2021, 11:06 AM
ELVIRA Group: Benefactors Posts: 8,493 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
John did you drill a new hole? Looks like everything is stock. The PO did the conversion. (IMG:style_emoticons/default/smash.gif) No extra holes that I am aware of. |
Lo-Fi Version | Time is now: 28th April 2024 - 07:25 PM |
