Hose clamp tool, Bought the McMaster-Carr |
jim_hoyland |
Sep 15 2021, 11:53 AM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
We all probably tried squash ueezing a wire clamp with pliers and POOF -it’s flying…
Thanks to Bruce Stone; I ordered the Klein D514-8 slip joint hose clamp plier from McMaster/Carr Works great on all sizes of wire hose clamps Attached thumbnail(s) |
jrmdir |
Sep 15 2021, 12:11 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
A little Googling produced this:
https://www.garagejournal.com/forum/threads...ckwards.274576/ Apparently no one uses those types of clamps any more and the special pliers are only found on used tool websites. Model # is WF 45391. Do a search if you'd like to pick one up. Ron |
bdstone914 |
Sep 15 2021, 02:34 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Mc Master Carr has several types. Or cut a groove in a pair of plyers
nivekdodge |
Sep 15 2021, 04:14 PM
Member Group: Members Posts: 248 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
jim_hoyland |
Sep 15 2021, 04:44 PM
Mc Master Carr has several types. Or cut a groove in a pair of plyers Thanks Bruce. That’s the one. Their web page shows it gripping a wire hose clamp… (IMG:style_emoticons/default/smile.gif) |
PanelBilly |
Sep 15 2021, 04:47 PM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Harbor freight has one
bzettner |
Sep 15 2021, 04:59 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
Find an old pair of conventional pliers and grind a groove in each face of the jaws. Or go fancy and modify a pair of channel lock pliers to give you a wider range of clamping ability. (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations |
Sep 15 2021, 05:08 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have a set of those Craftsman pliers and to be honest, they don't work that well on those hose clamps. I wish I knew what did, they are a PITS
914Sixer |
Sep 15 2021, 08:31 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Water pump hose clamp pliers
jim_hoyland |
Sep 16 2021, 05:31 AM
jim_hoyland |
Sep 30 2021, 02:11 PM
Updated first post after receiving the tool.,.
930cabman |
Sep 30 2021, 04:21 PM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Mc Master Carr is a great resource for many items, including Schnorr washers. Place your order before noon, often its at your your shop the next day.
jim_hoyland |
Sep 30 2021, 07:06 PM
Mc Master Carr is a great resource for many items, including Schnorr washers. Place your order before noon, often its at your your shop the next day. And their customer service is excellent. I sent a message Sunday morning inquiring when my order would arrive. An hour later I received a response ! No automated response, a real human wrote back. |
L-Jet914 |
Sep 30 2021, 10:54 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I wish I knew these existed a few weeks ago when I was replacing my drain hoses in the engine compartment haha. I will definitely be picking up a set. I some how got regular pliers to work with a lot of expletives somewhere in there.
930cabman |
Oct 1 2021, 05:02 AM
I wish I knew these existed a few weeks ago when I was replacing my drain hoses in the engine compartment haha. I will definitely be picking up a set. I some how got regular pliers to work with a lot of expletives somewhere in there. There is a "correct tool" for almost any job, finding it can sometimes be a challenge |
toolguy |
Oct 1 2021, 09:17 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Try Upholstery hog ring pliers
L-Jet914 |
Oct 5 2021, 09:42 PM
While at work last Friday, I talked with the local Snap-On tool guy. I found out they make pliers for those constant tension hose clamps. He happened to have it on the truck too surprisingly. Part number HCP48CF.
Attached image(s) |
Shivers |
Oct 6 2021, 07:19 AM
Senior Member Group: Members Posts: 2,365 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:59 PM |
