Correcting the rear wheel to fender offset. |
Jonny Retrofit |
Sep 16 2021, 12:11 AM
Newbie Group: Members Posts: 23 Joined: 27-September 15 From: UK Member No.: 19,211 Region Association: None |
Hi Guys,
We are running 8 x 15 Fuchs on the back of our narrow body '14. With careful tyre choice and a mild fender pull this works great on the passenger side of the car. On the driver side, however, there is 5mm less clearance which appears to be a common issue. The wheels look great and I want to keep them so have been thinking about how to correct this offset. One option would be to modify the trailing arm front pivot tube. E.g. shorten on the inboard side and lengthen outboard, bringing the arm in by 5mm. Any thoughts on this approach with respect to the suspension geometry? The only thing I can think of is that the damper would be at a slightly different angle but I can't see 5mm across the length of the damper making that much difference. We don't have a rear ARB. Pretty sure the driveshaft has enough slack to cope with the 5mm reduced distance. Thoughts welcome! |
SirAndy |
Sep 16 2021, 12:35 AM
Resident German Group: Admin Posts: 41,636 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Thoughts welcome! Just pull the drivers side fender some more. Much quicker and cheaper than trying to refab the suspension. I take it you already rolled the fender lip? (IMG:style_emoticons/default/idea.gif) |
LefthandRev |
Sep 16 2021, 10:30 AM
Member Group: Members Posts: 75 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Thoughts welcome! Just pull the drivers side fender some more. Much quicker and cheaper than trying to refab the suspension. I take it you already rolled the fender lip? (IMG:style_emoticons/default/idea.gif) What Andy said. I have super minimal clearance on my driver's side, but passenger's is fine. How I test it after pulling, I got from watching the RWB mini-docs. Jack the car up, put a wheel or ramp under the wheel in question, then lower it down slowly until the car is resting on the object: Three wheels on the ground, one up. You should be able to slip a screwdriver along the length of the gap without issue. If not, put it back on the ground and pull it some more. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:39 AM |
