GB up Fresh air screen and seal Yes WCR $20 coupon works on these, Grills ONLY at $12, with seal $24.99 for both Active til Nov 10th |
Mikey914 |
Sep 22 2021, 09:25 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have been casting these by hand for some time as they are needed. We have finally stepped up to high volume tooling and you can benefit for that.
The grills are an important part of keeping larger debris items out of your airbox. They were a late car item but can be retrofitted into the early cars. You may not even notice that you have this as many were painted over as removing the airbox is a pain, and most body shops don’t want to even think about it. May are painted over. As I mentioned these were hand cast, that meant that we had to go through and clean up the flash on these in the center “grill area” this required a lot of time. These are “correct” for cars 1973-76 model years starting with VIN #24929. This set can be used for any model year as the grille only requires the top seal for backdating. We had been selling these at $25 a pop as there was a lot of labor in them. Making this jump in tooling makes a better quality part and we can reduce the cost of what we can sell them at. The GB price on these The seal me make is a silicone seal that you can use glycerin to help slide in place. The OEM seals are a very small and hard to keep seated seal that caused me lots of frustration, so I made the larger seal that is easier to hold in place and provides a water tight seal. Ian has even done up a great thread with a how to - https://youtu.be/Uhs6pedBOXM You may not need it now but the now you have the ability to save a good chunk of change. We are just finishing up these and they will be ready in about 14 days. Attached thumbnail(s) Attached image(s) |
NARP74 |
Sep 22 2021, 10:53 AM
Senior Member Group: Members Posts: 1,057 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Probably on my list and I don't even know it yet. I'm in.
Steve |
Sep 22 2021, 11:11 AM
914 Guru Group: Members Posts: 5,574 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I will take a set. I might need it someday...
ndfrigi |
Sep 22 2021, 11:18 AM
1 set for me Mark.
Mikey914 |
Sep 22 2021, 02:03 PM
Figured that since there were a few threads popping up on the airbox it was worth putting this up a little early. We also make many of the misc clips that hold these together so if you are missing one perfect time put back on.
Chris H. |
Sep 22 2021, 03:38 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Need one for sure!
Front yard mechanic |
Sep 22 2021, 03:46 PM
Senior Member Group: Members Posts: 1,158 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Fresh off the grill for me (IMG:style_emoticons/default/jsharp.gif)
PCH |
Sep 22 2021, 06:50 PM
Member Group: Members Posts: 140 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
Please count me in.
914Sixer |
Sep 22 2021, 08:16 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am in for one set of screen and seal.
DC_neun_vierzehn |
Sep 22 2021, 08:29 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
In for one screen and seal.
914xr75 |
Sep 23 2021, 06:33 AM
Member Group: Members Posts: 174 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
One screen and seal please.
914e |
Sep 23 2021, 12:33 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I will take a grill and seal just to have on hand.
808 WRX |
Sep 23 2021, 02:04 PM
Member Group: Members Posts: 58 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
I'm in for one set, maybe two (IMG:style_emoticons/default/beerchug.gif)
racer914 |
Sep 23 2021, 02:22 PM
Member Group: Members Posts: 79 Joined: 1-October 19 From: Keystone Heights, FL Member No.: 23,513 Region Association: South East States |
I will take a grill and seal set.
davep |
Sep 23 2021, 08:00 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I would be looking for 2 sets.
PaulFV8 |
Sep 23 2021, 08:41 PM
Member Group: Members Posts: 81 Joined: 2-August 20 From: Virginia, USA Member No.: 24,562 Region Association: None |
I’m in for two sets please
bob164 |
Sep 24 2021, 07:37 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
I'm in for a set.
Montreal914 |
Sep 24 2021, 10:33 AM
Senior Member Group: Members Posts: 1,544 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
In for a set!
Thank you! (IMG:style_emoticons/default/smile.gif) |
HansJan |
Sep 24 2021, 08:11 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Do all 914's have these?
If so, I need a set.... |
Mikey914 |
Sep 25 2021, 04:33 AM
Lo-Fi Version | Time is now: 5th May 2024 - 09:31 AM |
