Suggestions on 914/6 torsion bar size? |
Tdskip |
Oct 1 2021, 10:47 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi folks, hoping to get some thoughts on what torsion bar size people with 911 front suspension are running for road/touring cars? My current set up is too firm for comfortable use and to minimize down time I would like to have the replacement bars on hand.
I have not pulled the existing bars out but it's the bars, not the shocks, since I have new Koni shocks on the front that aren't harsh. Thanks! |
Oct 1 2021, 11:31 AM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hi folks, hoping to get some thoughts on what torsion bar size people with 911 front suspension are running for road/touring cars? My current set up is too firm for comfortable use and to minimize down time I would like to have the replacement bars on hand. I have not pulled the existing bars out but it's the bars, not the shocks, since I have new Koni shocks on the front that aren't harsh. Thanks! The smallest you can fit. I don't remember the stock 911 size but i think it's already bigger than a stock 914 bar. I prefer a bigger sway bar over bigger torsion bars for anything mostly street driven. (IMG:style_emoticons/default/driving.gif) |
Oct 1 2021, 11:56 AM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Hi folks, hoping to get some thoughts on what torsion bar size people with 911 front suspension are running for road/touring cars? My current set up is too firm for comfortable use and to minimize down time I would like to have the replacement bars on hand. I have not pulled the existing bars out but it's the bars, not the shocks, since I have new Koni shocks on the front that aren't harsh. Thanks! The smallest you can fit. I don't remember the stock 911 size but i think it's already bigger than a stock 914 bar. I prefer a bigger sway bar over bigger torsion bars for anything mostly street driven. (IMG:style_emoticons/default/driving.gif) I think the smallest is 18.9 and that's about 1mm larger than the 914 bar. |
Steve |
Oct 1 2021, 12:49 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Hi folks, hoping to get some thoughts on what torsion bar size people with 911 front suspension are running for road/touring cars? My current set up is too firm for comfortable use and to minimize down time I would like to have the replacement bars on hand. I have not pulled the existing bars out but it's the bars, not the shocks, since I have new Koni shocks on the front that aren't harsh. Thanks! The smallest you can fit. I don't remember the stock 911 size but i think it's already bigger than a stock 914 bar. I prefer a bigger sway bar over bigger torsion bars for anything mostly street driven. (IMG:style_emoticons/default/driving.gif) I think the smallest is 18.9 and that's about 1mm larger than the 914 bar. I'm running the 18.8mm 911 torsion bars, they are one mm bigger (17.8) than 914-4 torsion bars. The very early 911's did run 17.8, the same as a stock 914-4. I had a set and traded it to Bruce for the later 18.8 |
Tdskip |
Oct 1 2021, 02:17 PM
Thank you gentlemen, appreciate the information and help.
Superhawk996 |
Oct 1 2021, 02:34 PM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I prefer a bigger sway bar over bigger torsion bars for anything mostly street driven. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) Spot on. (IMG:style_emoticons/default/smilie_pokal.gif) You use springs (or torsion bars) to support the weight of the vehicle and to absorb vertical inputs. Body roll is controlled via Anti-Roll Bar. |
Oct 1 2021, 03:11 PM
I prefer a bigger sway bar over bigger torsion bars for anything mostly street driven. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) Spot on. (IMG:style_emoticons/default/smilie_pokal.gif) You use springs (or torsion bars) to support the weight of the vehicle and to absorb vertical inputs. Body roll is controlled via Anti-Roll Bar. A lot of people think bigger is better but torsion bar spring rate ramps up quickly and too big makes the car very uncomfortable. |
roblav1 |
Oct 1 2021, 07:53 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Everybody is different! I prefer spring rate over bar!
Oct 1 2021, 08:57 PM
Everybody is different! I prefer spring rate over bar! Some of us like their dentures to stay inside the mouth while driving ... (IMG:style_emoticons/default/slits.gif) |
screenguy914 |
Oct 14 2021, 09:54 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Spring rate provides degrees of ride firmness.
Sway bars, since they connect the opposing corner, provide degrees of ride harshness. And there are shocks that can do both. Balance is the key. Sherwood |
Tdskip |
Oct 14 2021, 10:06 PM
Checking on this tomorrow and have 19mm on hand.
Lo-Fi Version | Time is now: 19th May 2024 - 03:56 PM |
