Center Console Cover, alternatives to carpet |
RFoulds |
Oct 4 2021, 06:47 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Changing my race car into part time street use. Re-doing the interior but want to keep it fairly sparse and business like.
Has anyone ever fabricated either an aluminum cover or maybe a fiberglass cover for the center tunnel? I want add as little carpet as possible. Seeing some of the Stinger 911 cars with a fiberglass center running the length of the tunnel gave me ideas. If no one has ever tried this, I will start getting quotes, just didnt want to duplicate someone elses efforts. |
tygaboy |
Oct 5 2021, 07:39 AM
914 Guru Group: Members Posts: 5,287 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Same sort of idea, just over a custom base. I removed the factory tunnel and made a 1.5" x 1" steel frame that's then covered with a removable steel cover. I used 18 ga for the cover, probably should have used 20, just for the weight savings. I'm thinking of pulling a mold of the cover and duplicating it in fiberglass or carbon fiber.
Attached thumbnail(s) |
Cracker |
Oct 5 2021, 07:40 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Are you meaning "Singer 911"? If so, your best bet would be to study the myriad of designs that Tygaboy built - all for the same project, too! (IMG:style_emoticons/default/biggrin.gif)
His thoughtful insight goes beyond anything Singer puts out (jmho)... Good luck! |
RFoulds |
Oct 5 2021, 05:40 PM
Same sort of idea, just over a custom base. I removed the factory tunnel and made a 1.5" x 1" steel frame that's then covered with a removable steel cover. I used 18 ga for the cover, probably should have used 20, just for the weight savings. I'm thinking of pulling a mold of the cover and duplicating it in fiberglass or carbon fiber. YES! thats exactly what I am after. For Gawd's sake, pull a mold and sell that in FG!! OR, make me the same metal one! |
Lo-Fi Version | Time is now: 9th May 2024 - 06:37 PM |
