What is this part, Dumb question of the day |
tsvo |
Oct 9 2021, 12:10 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Hello, I am hoping someone can save me some time. I think this tube/hose fell off my car today. Didn't affect the drive or running. Looks to me like it's probably part of the heating. I have not looked under the car at all yet.
Can anyone help me identify it? Thanks in advance for your time. Regards, Terry |
IronHillRestorations |
Oct 9 2021, 12:13 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Doesn't look like anything to me (IMG:style_emoticons/default/biggrin.gif) (no pic)
914Sixer |
Oct 9 2021, 12:15 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It's SURE is stealthy.
tsvo |
Oct 9 2021, 12:24 PM
Hello, I am hoping someone can save me some time. I think this tube/hose fell off my car today. Didn't affect the drive or running. Looks to me like it's probably part of the heating. I have not looked under the car at all yet. Can anyone help me identify it? Thanks in advance for your time. Regards, Terry Attached thumbnail(s) |
Dustin |
Oct 9 2021, 12:28 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
It's part of the heater system. From heat exchangers to blower motor. I think.
tsvo |
Oct 9 2021, 12:38 PM
That is what I was thinking. Thank you for the response. I just haven't looked under the car yet.
It's part of the heater system. From heat exchangers to blower motor. I think. (IMG:style_emoticons/default/biggrin.gif) |
JamesM |
Oct 9 2021, 12:39 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It's part of the heater system. From heat exchangers to blower motor. I think. (IMG:style_emoticons/default/agree.gif) that it normally connects to the forward outside edge of the heat exchanger and runs up through your engine tin. that little tab normally is perpendicular to the pipe and bolts to the tin. If you look in your engine bay you will notice a big empty hole that this part used to reside in. Not a critical part though. I mean unless you want a fully functioning heating system. |
tsvo |
Oct 9 2021, 12:43 PM
Thank you for the detailed response. I'm not to worried about the heat. I want it to work, but I don't drive it in bad weather. I will fix it, just probably not today.
It's part of the heater system. From heat exchangers to blower motor. I think. (IMG:style_emoticons/default/agree.gif) that it normally connects to the forward outside edge of the heat exchanger and runs up through your engine tin. that little tab normally is perpendicular to the pipe and bolts to the tin. If you look in your engine bay you will notice a big empty hole that this part used to reside in. Not a critical part though. I mean unless you want a fully functioning heating system. (IMG:style_emoticons/default/biggrin.gif) |
914werke |
Oct 9 2021, 12:46 PM
"I got blisters on me fingers" Group: Members Posts: 10,077 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Commonly known as a J tube
rhodyguy |
Oct 9 2021, 02:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Broken tabs. The fasteners are prob still in the Heat exchanger and engine shelve. There are L&R versions. Serviceable used ones don't cost much. Get one and cap it.
Lo-Fi Version | Time is now: 20th May 2024 - 10:29 AM |
