914 LS Boxster Pics/Info |
Gearup |
Oct 10 2021, 01:48 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Good afternoon,
Was wondering if I could get info and pictures on peoples setups with their boxster s transmissions with the LS motor. Did you use the stock 6 speed Boxster shifter and cables. If so, did you created a pedestal to raise its height (Pics please). If not, what shifter did you use? Did you use a stock pedal cluster? Is there an aftermarket pedal cluster that could be set up for a hydraulic clutch and throttle cable that you have used? I have most everything but the tranny Mount and engine Mount bar. Any input and pics are appreciated. Brett |
ClayPerrine |
Oct 10 2021, 02:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,450 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Good afternoon, Was wondering if I could get info and pictures on peoples setups with their boxster s transmissions with the LS motor. Did you use the stock 6 speed Boxster shifter and cables. If so, did you created a pedestal to raise its height (Pics please). If not, what shifter did you use? Did you use a stock pedal cluster? Is there an aftermarket pedal cluster that could be set up for a hydraulic clutch and throttle cable that you have used? I have most everything but the tranny Mount and engine Mount bar. Any input and pics are appreciated. Brett I don't have an LS engine in my car, but I have a Cayman 6 speed G86-21 in it. Info on my build isHere. The page has the shifter info in it. There are also pictures of how I hooked up the hydraulic clutch master cylinder in the thread. Clay |
tygaboy |
Oct 10 2021, 06:46 PM
914 Guru Group: Members Posts: 5,289 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
LS3 and Boxster S G86-20. I'm running the Numeric shifter on a custom riser that then gets a cover. Numeric cables, too. Stock length.
I'm going to be selling my Renegade transmission mount set up and probably the engine cross bar. PM me if you'd like to talk details. Re: the pedals, I'm running the Tilton 600 series 3-pedal. I used to run a cable to my ITBs but I'm switching to DBW throttle body. Attached thumbnail(s) |
partwerks |
Oct 10 2021, 08:02 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I used the stock pedal, and made a bracket for the slave cylinder.
Used the stock shifter, but put some goodies in it from fuction first. Mechanic put it up on stilts. Would rather it was sitting back a bit further, but can't shrink the cables. On the foot feed, I used part of the new, and part of the old system. Used the old pedal with linkage that hooked up to the DBW that was mounted vertically on the front wall. |
Gearup |
Oct 11 2021, 11:40 AM
Thanks guys. Appreciate any and all input.
Brett |
windforfun |
Oct 11 2021, 02:21 PM
Senior Member Group: Members Posts: 1,779 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
LS3 and Boxster S G86-20. I'm running the Numeric shifter on a custom riser that then gets a cover. Numeric cables, too. Stock length. I'm going to be selling my Renegade transmission mount set up and probably the engine cross bar. PM me if you'd like to talk details. Re: the pedals, I'm running the Tilton 600 series 3-pedal. I used to run a cable to my ITBs but I'm switching to DBW throttle body. Gotta love it. You're an artist! |
Lo-Fi Version | Time is now: 11th May 2024 - 06:44 PM |
