Good afternoon,
Was wondering if I could get info and pictures on peoples setups with their boxster s transmissions with the LS motor. Did you use the stock 6 speed Boxster shifter and cables. If so, did you created a pedestal to raise its height (Pics please). If not, what shifter did you use? Did you use a stock pedal cluster? Is there an aftermarket pedal cluster that could be set up for a hydraulic clutch and throttle cable that you have used? I have most everything but the tranny Mount and engine Mount bar. Any input and pics are appreciated.
Brett
