WTB : passenger door stay |
Medtner3 |
Oct 12 2021, 07:08 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I did a rebuild with 914 rubber parts .. but I need a whole new door stay unfortunately I have several parts that are worn that pop and man it's aggravating. The pin that holds the door stay arm is not my issue, nor bushings. According to Pelican parts " there really is no good way to rebuild them" and I wish I had read that before I rebuilt mine because I have to agree with this statement unless of course 90% of your parts are good and you just need the bushings
Perhaps a ton of grease would help mine but I can see the large pin in the door stay lurch when opening the door. looks like Pelican Parts might have them but I thought I would check here first |
carl k |
Oct 13 2021, 06:07 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
@Medtner3
I have this one with a worn out arm. It includes the base, which is pretty much the only part not supplied with the 914rubber kit. The pivots are tight. -Carl |
Medtner3 |
Oct 13 2021, 06:09 PM
@Medtner3 I have this one with a worn out arm. It includes the base, which is pretty much the only part not supplied with the 914rubber kit. The pivots are tight. -Carl the pivots are my concern ... I will pm you |
Lo-Fi Version | Time is now: 21st May 2024 - 06:51 AM |
