Factory Underside Corrosion Protection, What did they coat the panels with? |
pek771 |
Oct 12 2021, 07:49 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
I can't determine what treatment was used on a 70 regarding the underside. It looks like the steel was coated with something. Anyone have any ideas?
TIA Pat |
pek771 |
Oct 14 2021, 10:03 AM
Everything in the military was coated with cosmoline. There is some other stuff Porshe used on magnesium to protect it, which I think is a cousin to cosmoline. I have neither, but it is getting cleaned from to back I want to get this tub cleaned and remove the spots where water hides...like in the pedal assembly. Then I can coat it with Second Skin and undercoating.
I'm also going to mix in some microspheres with the Second Skin Acoustic stuff, for some additional sound deadening and thermal insulation |
bbrock |
Oct 15 2021, 07:57 AM
There is some other stuff Porshe used on magnesium to protect it, which I think is a cousin to cosmoline. Tectyl - I put it on my engine and transmission after rebuild. Very much like cosmoline. It melts and "flows" when the engine and trans are hot and then resolidfies into a waxy coating when they cool down. I thought it would burn off int he first thousand miles but it is still there after 2,500. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:14 AM |
