Finally Running, Help me keep it that way (starter issue) |
BenNC |
Jul 22 2003, 09:13 PM
Member Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
After working on it for about ayear I finally have my baby running. I finally really understand why these cars have such a loyal following. All I did was drive and grin.
I had about 36 carefree hours before I started running into problems. I know that it has been the topic of several threads, but I'm have starting issues. I drove all over the place one day. Start, stop, start, stop etc... That night I got rained on and the car would not start in the morning. Classic symptoms of all the electricals work but starter won't turn. After a push start (with help from my girlfriend who, amazingly, is still impressed that I got the car running), I drove it home. I started the car six or seven times that day while driving around with no problems. When I got home that night the same thing happened. I cleaned off all the wires on the starter and the ground strap from the tranny. Still no go. I can start it no problem by crossing the posts, but not from the key. What is my logical progression of checks? I know about the switch problems and seat belt Nazi Sensor, but just want to waste as little time as possible on unlikely scenarios. Thanks |
Brad Roberts |
Jul 22 2003, 10:21 PM
Do you have a cover on the relay board ?? I would check the yellow wire leading to the 14 pin connector on the backside of the relay board.
Welcome back Ben. B |
Aaron Cox |
Jul 22 2003, 10:44 PM
i had same problem after rains and such. buy a new ignition switch (13 $ )
rhodyguy |
Jul 23 2003, 08:07 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
something else to consider while trouble shooting. check the condition of the spade connections, the yellow wires. make sure the terms are clean and that the wires aren't wiggly. slip the slide cover off the front harness on the relay board. push each wire down and make sure they are all in solid. the wire at the # 13 was not making contact, it's a ground point. this only took 3 days. take your time and realley study the CORRECT wiring diagram. with the +terminal disconnected from the bat start checking continuity to each junction point. when cont disappears. the light should go on in your brain.
after the silver car was up and the wife was going for the first ride the question was, "are we going to have to push it like the white car?" "nope". first shut down 20 miles from home. "help me give it a little push". one connection, yellow wire, was as loose as the day is long and had slipped off. a shot of contact cleaner and a new connector, very nice and tight now. haven't had a prob since. just "yanking" the start switch is a dangerous means of trouble shooting in my book. unless the top is off and it's a hurricane, why rain rain affect the switch? kevin kevin |
ninefourteener |
Jul 23 2003, 08:12 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
I agree with the statement a couple above.
That damn lock cylinder in the steering column is a piece of shit. From what I understand, those things go bad all the time. Swap that out, it may just save you a lot of hassle, and give you piece of mind. A similar occurence happened to me, and that was the problem. For 20 bucks, what can you lose? |
rhodyguy |
Jul 23 2003, 08:19 AM
why in the name of hell would the lock in the cyl cause a no start issue? is it a ground point or a hot connection? unable to turn key? sure. but a intermitent start issue (IMG:style_emoticons/default/blink.gif) ?
kevin |
echocanyons |
Jul 23 2003, 09:29 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
the ignition switch on the dash is often to blame and I found when mine was going out that if I would turn it 20 times or so at least one of those times it would catch.
I also had trouble with my POS flaps rebuilt starter overheating on long trips. I only noticed it after taking a long trip but after it cooled down it worked fine, this happened 4 or five times. Lastly check the connections on the starter itself sometimes they can get corroded with the rain and cause it not to get a clean connection addendum----I guess I should have read your post more carefully. The starter would not turn over when overheated if I jumped the connections at the starter itself. The Ign switch was very erratic in its starting, but would start if I jumped the connections. I read that you cleaned the connections well so sorry |
BenNC |
Jul 23 2003, 11:02 AM
OK, got a new switch. I'll check the wires and such tonight and see what happens.
Thanks for the help. |
onrails |
Jul 23 2003, 03:22 PM
if the world didn't suck,,we would all fall off Group: Members Posts: 118 Joined: 21-July 03 From: tulsa,ok Member No.: 929 |
had that problem,for a-long time! ,,,,,,,,,finally had to
replace the alternator & noticed that the ground was loose. put the new one in,made sure it was grounded good,,,,,,,,,,,,,,,,& haven't had a problem thus far. sounds kind-of strange,,,,but it worked! |
Brad Roberts |
Jul 23 2003, 03:50 PM
Welcome "Onrails" to the BBS !! (IMG:style_emoticons/default/clap56.gif)
Lots of Oakies checking in over the last few months. Will we see you at the MUSR in Hot Springs this year ? B |
TheCabinetmaker |
Jul 23 2003, 03:57 PM
QUOTE(Brad Roberts @ Jul 23 2003, 01:50 PM) Welcome "Onrails" to the BBS !! (IMG:style_emoticons/default/clap56.gif) Lots of Oakies checking in over the last few months. Will we see you at the MUSR in Hot Springs this year ? B If your going to call us Okie's, at least spell it right! LOL BTW, most everything you've heard about Okla is true!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
onrails |
Jul 23 2003, 03:58 PM
thanks brad! & yes i will be in hot springs for my second ramble,,,,,loved the first,,have to come!
i look forward to meeting everyone who is making the trip! see ya then (IMG:style_emoticons/default/beerchug.gif) |
Brad Roberts |
Jul 23 2003, 04:00 PM
I never claimed I could speel...
B |
onrails |
Jul 23 2003, 04:05 PM
lmao brad! you sound really fun,,,,look forward to our meeting! p.s. that your car??? oooooooo!
Brad Roberts |
Jul 23 2003, 04:43 PM
Not my car. I'm like Dave Darling.. I dont have a running/driving 914.. I just talk about them.
B |
BenNC |
Jul 23 2003, 07:20 PM
Sho' nuff it was the ignition switch. Obligatory crack around the base. Thanks for the input.
Off to break something else. I'll let you know when I do. |
jdogg |
Jul 23 2003, 07:40 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Great deal, Ben........ Are you coming friday?
Lo-Fi Version | Time is now: 14th May 2024 - 11:59 AM |
