wiring help please, 1974 2.0 with carbs... |
Badinfluence1 |
Oct 13 2021, 12:21 AM
Newbie Group: Members Posts: 32 Joined: 27-December 20 From: astoria oregon Member No.: 25,022 Region Association: Pacific Northwest |
where do the wires from the coil go? The condenser on the side of the distributor goes on the positive side. Do the other wires go to the main wiring harness under the battery in a bundle of 3 not the 4 that goes to the battery -yes? The haynes manual is difficult to understand- thanks for any help
Badinfluence1 |
Oct 13 2021, 12:27 AM
this is the wiring harness under the seat-DO I need it if I have carbs? Also what does it control ?
Shivers |
Oct 13 2021, 04:52 AM
Senior Member Group: Members Posts: 2,369 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
A little light reading. Stuff under seat
http://www.914world.com/bbs2/index.php?showtopic=246814 Basically: The coils negative pole is to the dizzy, positive is hot from the ignition switch. |
barefoot |
Oct 13 2021, 05:49 AM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
this is the wiring harness under the seat-DO I need it if I have carbs? Also what does it control ? This is for seat belt warning & ignition cut-out if seatbelts not connected. You need to interconnect the big yellow wires (as shown) & cap everything else off. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:34 AM |
