Road Atlanta, VDCA Race Clip |
wndsrfr |
Oct 14 2021, 08:02 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
infraredcalvin |
Oct 15 2021, 07:58 AM
Distracted Member Group: Members Posts: 1,509 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Whoops looks like 4th to 3rd instead of 5th, wheels locked up on you… way to hold it together, but then you tried to power through the grass on slicks….
Time to check your valves, that’s how I blew my last engine… TIV though, 5th to 2nd, locked wheels and spun, bent a valve that ultimately broke off and put a piston through the top of the case…. |
wndsrfr |
Oct 16 2021, 08:20 AM
Whoops looks like 4th to 3rd instead of 5th, wheels locked up on you… way to hold it together, but then you tried to power through the grass on slicks…. Time to check your valves, that’s how I blew my last engine… TIV though, 5th to 2nd, locked wheels and spun, bent a valve that ultimately broke off and put a piston through the top of the case…. Close...but I do 4th to 3rd every lap right there....listen carefully.... |
Cracker |
Nov 18 2021, 10:51 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Hey John...!
Your line (not the ideal angle) approaching T2 combined with your downshift (and possibly braking) led to your spin...I've seen it there many times. It is off-camber at that apex (which you were right of); I can help you dial that in. Call me when you have time and we'll address some other areas, too. Happy Thanksgiving! Tony |
Lo-Fi Version | Time is now: 28th April 2024 - 10:28 AM |
