SOLD early headlight switch |
DC_neun_vierzehn |
Oct 14 2021, 10:03 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
A few months back, I posted a WTB headlight switch here in the Classifieds for my '73 (due to dimmer not working smoothly).
A kind fellow responded that he had what I needed. Unfortunately, what he sent turned out not to be the right headlights switch version. He sent an early headlight switch (more narrow, 10 posts, I'm told used 70-'72). Seems like some '73s (depending upon when in '73 your car was produced) had the early headlight switch, while others had the later headlight switch. Thus, I'm offering this early headlight switch up to the next person for what I paid ($30). I was told it worked fine. I have no way of testing it since it doesn't match my wiring. The switch on the left is the switch in my car (a late switch) that I need to replace. The switch on the right (early switch) is the one I'm selling. |
DC_neun_vierzehn |
Oct 14 2021, 10:06 PM
Attached thumbnail(s) |
JeffBowlsby |
Oct 15 2021, 09:32 AM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Easy to test for continuity and resistance of the dimmer circuit with this diagram.
https://bowlsby.net/914/WiringHarnesses/doc...ashSwitches.pdf |
roundtwo |
Oct 15 2021, 09:40 AM
Member Group: Members Posts: 269 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
I'd like to buy it. Would be super if I knew it worked. PM sent
DC_neun_vierzehn |
Oct 15 2021, 02:00 PM
Easy to test for continuity and resistance of the dimmer circuit with this diagram. https://bowlsby.net/914/WiringHarnesses/doc...ashSwitches.pdf Thanks. I really wish I knew how to read that and put it to use. But sadly, I don’t. Willing to learn though! |
JeffBowlsby |
Oct 15 2021, 02:15 PM
Easy to test for continuity and resistance of the dimmer circuit with this diagram. https://bowlsby.net/914/WiringHarnesses/doc...ashSwitches.pdf Thanks. I really wish I knew how to read that and put it to use. But sadly, I don’t. Willing to learn though! The diagrams indicate the circuitry internal to the switch. Do you have an ohmmeter and know how to use it? If not its a helpful basic tool/skill that you may be interested in acquiring. If you buy an ohmmeter, sometimes they are in a combined meter called a DVM (digital volt meter) which include s voltage meter and sometimes other functions. A cheap one will work sufficeintly, or buy a good meter for better quality. Look for one with an audio signal output. These meters have two leads (probes) and when used as an ohmmeter you touch the probe tips together the meter or the audio signal which will indicate continuity. Using the meter on the switch, just touch the tips to each end of a circuit as indicated to see if it has continuity, that is all you are testing = continuity. The ohmmeter function will allow you to read the resistance of the dimmer circuit. |
DC_neun_vierzehn |
Oct 16 2021, 01:14 PM
Easy to test for continuity and resistance of the dimmer circuit with this diagram. https://bowlsby.net/914/WiringHarnesses/doc...ashSwitches.pdf Thanks. I really wish I knew how to read that and put it to use. But sadly, I don’t. Willing to learn though! The diagrams indicate the circuitry internal to the switch. Do you have an ohmmeter and know how to use it? If not its a helpful basic tool/skill that you may be interested in acquiring. If you buy an ohmmeter, sometimes they are in a combined meter called a DVM (digital volt meter) which include s voltage meter and sometimes other functions. A cheap one will work sufficeintly, or buy a good meter for better quality. Look for one with an audio signal output. These meters have two leads (probes) and when used as an ohmmeter you touch the probe tips together the meter or the audio signal which will indicate continuity. Using the meter on the switch, just touch the tips to each end of a circuit as indicated to see if it has continuity, that is all you are testing = continuity. The ohmmeter function will allow you to read the resistance of the dimmer circuit. Thanks Jeff! Sounds like I need to go buy DVM w/ an ohmeter and watch some YouTube videos. I will add this to my tool purchase list |
DC_neun_vierzehn |
SOLD
Lo-Fi Version | Time is now: 5th May 2024 - 09:35 PM |
