GB brake reservoir covers $9 after GB $14, Codes going out 2/09/22 |
Larry.Hubby |
Jan 22 2022, 09:30 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
If the GB is still open, I'll take two of the thinner ones.
Mikey914 |
Jan 23 2022, 12:30 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, it is and just having some issue getting codes generated. Will get these out shortly,
Mark |
Mikey914 |
Feb 9 2022, 02:34 PM
Well the code really are out now.
Found that the thinner plastic wasn't readily available locally anymore. Had to source it and get it shipped in. It is in limited quantity right now. So we will make the thinner ones as long as we can get the material, the cost is the same. We made the fist ones with the holes, so as noted in the PMs sent PLEASE use the message if you want without the hole for the overflow tube. Thanks all for your patience. Mark |
ndfrigi |
Feb 9 2022, 02:59 PM
Well the code really are out now. Found that the thinner plastic wasn't readily available locally anymore. Had to source it and get it shipped in. It is in limited quantity right now. So we will make the thinner ones as long as we can get the material, the cost is the same. We made the fist ones with the holes, so as noted in the PMs sent PLEASE use the message if you want without the hole for the overflow tube. Thanks all for your patience. Mark Hi Mark, the 9am hose is not showing on your site. Thanks again! |
Mikey914 |
Feb 10 2022, 12:00 AM
Well the code really are out now. Found that the thinner plastic wasn't readily available locally anymore. Had to source it and get it shipped in. It is in limited quantity right now. So we will make the thinner ones as long as we can get the material, the cost is the same. We made the fist ones with the holes, so as noted in the PMs sent PLEASE use the message if you want without the hole for the overflow tube. Thanks all for your patience. Mark Hi Mark, the 9am hose is not showing on your site. Thanks again! It's right here https://914rubber.com/new-brake-hose-9mm-set-of-2 |
Lucky9146 |
Feb 10 2022, 12:45 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,607 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
If GB still available I will take one thick please.
Thanks! |
Lo-Fi Version | Time is now: 27th April 2024 - 12:47 PM |
