Hydraulic Clutch |
Hydraulic Clutch |
sharper |
Oct 21 2021, 12:18 PM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
I want to convert over to a hydraulic clutch as I believe it will make for easier shifting and driving. I have a 915 transmission in mine and the pedal likes to "spring" back at me right when the clutch is engaging. I've read some post in here from a few years back and it seems I need some brackets to support the master and slave cylinders. As I do not have the tools to create these, I was wondering if anyone knew of a source that I could purchase them from (or maybe has some laying around?).
Steve |
Oct 21 2021, 01:01 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I want to convert over to a hydraulic clutch as I believe it will make for easier shifting and driving. I have a 915 transmission in mine and the pedal likes to "spring" back at me right when the clutch is engaging. I've read some post in here from a few years back and it seems I need some brackets to support the master and slave cylinders. As I do not have the tools to create these, I was wondering if anyone knew of a source that I could purchase them from (or maybe has some laying around?). Does your pedal have the clutch return spring and omega spring on the trans? I have this setup on my 915 and makes the clutch more of a on and off switch. There was someone in the past that was making the bracket for the "Master" hydraulic cylinder. The rear looked more simpler. Do a search. Here is one link. http://www.914world.com/bbs2/index.php?sho...75785&st=0# |
76-914 |
Oct 21 2021, 01:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ross Nellums had a bunch of the MC brackets made awhile back. He is on Facebook a lot. Someone sells the pull type slave cylinder and brackets but damned if I can remember the guy's name. (IMG:style_emoticons/default/confused24.gif)
FL000 |
Oct 22 2021, 12:18 PM
Member Group: Members Posts: 389 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
You can also try @dwillouby for the brackets. I got a set from him for my M/C but went a another route for the trans; not sure what the differences are for 901 vs 915 slave adapter.
You can also checkout my thread for what I did for my clutch master. Starts around post 117. http://www.914world.com/bbs2/index.php?sho...311&st=100# |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:33 AM |
