Door latch removal |
mlindner |
Oct 23 2021, 10:42 AM
Senior Member Group: Members Posts: 1,515 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Can the inner door latch be removed with out taking the door glass out. Thanks, Mark
dr914@autoatlanta.com |
Oct 23 2021, 10:43 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
mlindner |
Oct 23 2021, 01:11 PM
How George. roll window up all the way, remove glass guide/track in front of latch? Mark
FlacaProductions |
Oct 24 2021, 10:21 AM
Senior Member Group: Members Posts: 1,566 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Yeah - perhaps this is what Geoge meant to say......
Do you have a Haynes manual? If not - they're great reference - from page 203 - I haven't done it but this seems fairly clear - I hope this helps. 1 - remove the door trim panel and PVC sheeting 2 - remove the window rear guide channel: -wind the window fully down. -pull back the window weather strip until the window guide piece moves freely. -remove the crosshead screw from the guide piece. -pull the guide piece upward and outward. -remove the crosshead screw and washer at the bottom of the guid channel on the lower edge of the door. -remove the guide channel thru the opening in the door inner panel. Installation is the reverse of removal - apply a trace of general purpose grease to the inner edges of the guide channel and ensure that the speed nut is in position before the channel is installed. if necessary, adjust the bottom fastening screw for the satisfactory operation of the window. 3 - wind the window fully up 4 - detach the spring clip from the pull rod. 5 - move the lock latch to the vertical position, remove the three crosshead screws and pul the lock downwards out of the door. 6 - installation is reverse of the removal procedure - but ensure that the lock action is checked before the trim panel and guide channel are installed. also check that the opening lever is correctly aligned with the safety lever. |
robkammer |
Oct 24 2021, 11:35 AM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Can the inner door latch be removed with out taking the door glass out. Thanks, Mark If you;re referring to the door lock and latch assembly it's actually pretty easy unless you've got Popeye arms. I was able to replace mine without removing anything except the door panel. There was no plastic liner but 014 rubber has a nice kit for when you put it back together. I bought repro handle and lock assemblies from a well know supplier and I did have some fitment issues that required some WV engineering and Dremel work. The door latch was just gummed up and after soaking it for a day in simple green and then lanolin lube it was back to like new. Good luck! |
mlindner |
Oct 24 2021, 03:10 PM
Thanks Brian, thats what I needed. Best, Mark
FlacaProductions |
Oct 24 2021, 05:23 PM
To quote an earlier post: "certainly"
Glad it helped! |
mlindner |
Nov 28 2021, 03:08 PM
OK, finally removed my inner door latch. I found if I just unscrew the window channel on the bottom of the door and then leaned it forward that gave me the room to push lock/latch in and down and out. Did not have to remove channel.
Thanks robkammer and FlacaProduction. Mark |
Lo-Fi Version | Time is now: 29th April 2024 - 10:44 AM |
