engine hardware, help identify... how many? |
brant |
Oct 25 2021, 10:37 AM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
cleaning out more crates from the shed.
how many case through bolts go in a motor? I think I have multiple motors worth... and are the shorter studs with barrel nuts from the heads? how many of those does it take? thanks in advance. here is a picture of what I'm talking about brant Attached thumbnail(s) |
Superhawk996 |
Oct 25 2021, 08:05 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
We talking T4 motors or 911 motors?
The barrel nuts are definately 911 parts. Quick glance at the others look 911 too. There are 11 though case bolts on a 911 so I think you're 1 short. Should have 1 acorn nut and two hardened washers per through bolt. Those are missing. Of the head studs there are 4 per cylinder. The odd one out looks to be to be a stud with a time-sert still on it making the longer threaded end appear much fatter. I think thats what it is? A couple of those head studs pretty well look Vice Grip abused and I wouldn't reuse them. Easier to just use new head fastners as they are a pretty highly stressed part. |
bkrantz |
Oct 25 2021, 08:11 PM
914 Guru Group: Members Posts: 7,753 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Type 4 should have 6 through-case bolts plus 16 cylinder/head studs (8 short and 8 long).
brant |
Oct 26 2021, 08:59 AM
thank you both!
I'm cleaning out crates of parts that are roughly... from the same area... IE: 1 crate for front trunk, and another fore engine parts I think you are correct... bet these are all 911 parts that just accidently got mixed in. thank you! brant |
Lo-Fi Version | Time is now: 7th May 2024 - 01:10 AM |
