brant
Oct 25 2021, 10:37 AM
cleaning out more crates from the shed.
how many case through bolts go in a motor?
I think I have multiple motors worth...
and are the shorter studs with barrel nuts from the heads?
how many of those does it take?
thanks in advance.
here is a picture of what I'm talking about
brant
Superhawk996
Oct 25 2021, 08:05 PM
We talking T4 motors or 911 motors?
The barrel nuts are definately 911 parts. Quick glance at the others look 911 too.
There are 11 though case bolts on a 911 so I think you're 1 short. Should have 1 acorn nut and two hardened washers per through bolt. Those are missing.
Of the head studs there are 4 per cylinder. The odd one out looks to be to be a stud with a time-sert still on it making the longer threaded end appear much fatter. I think thats what it is? A couple of those head studs pretty well look Vice Grip abused and I wouldn't reuse them. Easier to just use new head fastners as they are a pretty highly stressed part.
bkrantz
Oct 25 2021, 08:11 PM
Type 4 should have 6 through-case bolts plus 16 cylinder/head studs (8 short and 8 long).
brant
Oct 26 2021, 08:59 AM
thank you both!
I'm cleaning out crates of parts that are roughly... from the same area...
IE: 1 crate for front trunk, and another fore engine parts
I think you are correct... bet these are all 911 parts that just accidently got mixed in.
thank you!
brant
