replacing bonnet rubber |
63acornwall |
Oct 27 2021, 10:01 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
My 1975 914 still has what looks like the original bonnet rubber seal . there are gaps where the rubber has shrunk , some of the mitred joints have parted , so I thought I would replace it .
Not looking like a good decision ! I bought a 'new' seal from another 914 owner , it was bundled up for postage , and that crushed some of the sections . This was 2 years back so I pegged it out with some weights to regain its original contours This seal is all in one piece and the material appears to be synthetic grey-black foam rather than solid old school black rubber . OK , so I decided to fit it today . Carefully removed the pieces of the old stuff , the old adhesive had lost its grip so that was easy , no paint removed ! Offer up new seal . The sharp angles at the windscreen end of the bonnet are not well matched to the new seal , but could be persuaded to fit without breaking the mitre joint.....but all the long straight sections have to be stretched . so much so that I think the corner joints will part. So have downed tools on it . can anyone point me at the proper procedure? Im guessing that glueing down corner before stretching to next corner is necessary Am also thinking that there might be a better replacement seal out there , I probably have a poor copy of the OEM seal ? |
63acornwall |
Oct 27 2021, 10:34 AM
OK , am replying to my own post ! Just found this on youtube from 914Rubber
https://www.youtube.com/watch?v=f6_fPjX4b8A |
PanelBilly |
Oct 27 2021, 10:36 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Some double back rape will help hold it in place until it relaxes.
rgalla9146 |
Oct 27 2021, 01:40 PM
Some double back rape will help hold it in place until it relaxes. The originals were running material for the straight sections and had molded one piece rear corners glued to the straights. Those ~50 degree molded rear corners did not fail and did fit well. It's hard to find originals in usable condition |
63acornwall |
Oct 28 2021, 05:31 AM
OK , thanks guys . I think I might keep the original back corner pieces and cut the 'new' seal to butt up to them , there is enough straight material to avoid putting stretching stress on the front corners .
Lo-Fi Version | Time is now: 6th May 2024 - 09:54 AM |
