My 1975 914 still has what looks like the original bonnet rubber seal . there are gaps where the rubber has shrunk , some of the mitred joints have parted , so I thought I would replace it .
Not looking like a good decision ! I bought a 'new' seal from another 914 owner , it was bundled up for postage , and that crushed some of the sections . This was 2 years back so I pegged it out with some weights to regain its original contours
This seal is all in one piece and the material appears to be synthetic grey-black foam rather than solid old school black rubber .
OK , so I decided to fit it today . Carefully removed the pieces of the old stuff , the old adhesive had lost its grip so that was easy , no paint removed !
Offer up new seal . The sharp angles at the windscreen end of the bonnet are not well matched to the new seal , but could be persuaded to fit without breaking the mitre joint.....but all the long straight sections have to be stretched . so much so that I think the corner joints will part. So have downed tools on it .
can anyone point me at the proper procedure?
Im guessing that glueing down corner before stretching to next corner is necessary
Am also thinking that there might be a better replacement seal out there , I probably have a poor copy of the OEM seal ?
