Engine bay stud, What's it for? Klingon cloaking device... |
Quinn Moore |
Oct 27 2021, 03:54 PM
Qmoore Group: Members Posts: 106 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
dr914@autoatlanta.com |
Oct 27 2021, 04:06 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
unscrew the knurled nut then twist the relay board cover from the back over towards the right side of the car and it will come out after lifting (you can also unscrew the two voltage regulator screws. The hole in the engine insulator pad is for the seat belt retractor
Engine is out for a rebuild, builder gave me a short list of things I can do in the meantime. One being engine bay sound pad is not secured very well in "certain areas". Which is true. So two things...the relay board cover is a real b@&ch to get off....what is the stud above it for? Thx, QM |
Quinn Moore |
Oct 27 2021, 04:43 PM
unscrew the knurled nut then twist the relay board cover from the back over towards the right side of the car and it will come out after lifting (you can also unscrew the two voltage regulator screws. The hole in the engine insulator pad is for the seat belt retractor Engine is out for a rebuild, builder gave me a short list of things I can do in the meantime. One being engine bay sound pad is not secured very well in "certain areas". Which is true. So two things...the relay board cover is a real b@&ch to get off....what is the stud above it for? Thx, QM Thx doc. So...was the pad originally "glued" (or adhered to) the wall? I see 4 or 5 retaining buttons. Or both? The pad looks misaligned or at at a minimum, drooping on the right side. (No adhesive, it's loose). Thank you, QM |
burton73 |
Oct 27 2021, 05:01 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This is the stuff that works well. Amazon $13.00
It is hard to mussel the pads you have a tab on the top right side and there are buttons but these are hard to get right. Bob B |
Quinn Moore |
Oct 28 2021, 04:05 PM
NARP74 |
Oct 28 2021, 04:49 PM
Senior Member Group: Members Posts: 1,050 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Where did that pad come from? I'll be pulling my engine soon and my pad has already fallen off so I removed it.
bkrantz |
Oct 28 2021, 08:51 PM
914 Guru Group: Members Posts: 7,737 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
SKL1 |
Oct 28 2021, 11:15 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I wouldn't even bother with a pad- it only attracts moisture and you know what that leads to...
It's not like we can make a 914 quiet!! I never bothered to replace it on my '73 when I restored it, and my '71 never came with one. Don't miss it. |
Quinn Moore |
Oct 29 2021, 07:24 AM
VaccaRabite |
Oct 29 2021, 11:39 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have the closed cell foam one that 914Rubber sells.
I have been trying to make my 914 more quiet and adding the backpad helped a LOT. I used wide fender plugs to hold it in place, as well as the clips. No glue, so I can take it out and clean behind it when needed. Zach |
NARP74 |
Oct 29 2021, 12:00 PM
I have the closed cell foam one that 914Rubber sells. I have been trying to make my 914 more quiet and adding the backpad helped a LOT. I used wide fender plugs to hold it in place, as well as the clips. No glue, so I can take it out and clean behind it when needed. Zach Thank you |
Quinn Moore |
Oct 29 2021, 12:13 PM
I have the closed cell foam one that 914Rubber sells. I have been trying to make my 914 more quiet and adding the backpad helped a LOT. I used wide fender plugs to hold it in place, as well as the clips. No glue, so I can take it out and clean behind it when needed. Zach Thank you I like that idea. Thx Zach QM |
Mikey914 |
Oct 29 2021, 06:53 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wait til you switch to a real pad. The carpet that's there may do something, but the pad will be even better.
Quinn Moore |
Nov 1 2021, 03:23 PM
bkrantz |
Nov 1 2021, 07:55 PM
I would start with 3M adhesive remover. It often does the job, and is safe on paint (but always test first).
Quinn Moore |
Nov 2 2021, 06:26 AM
Quinn Moore |
Nov 5 2021, 04:33 PM
BeatNavy |
Nov 5 2021, 04:47 PM
That looks great - clean as a whistle. Great job.
I remember years ago spending hours with a toothbrush and mineral spirts and thinner trying to get the nasty undercoating off the firewall. It was nasty. |
Quinn Moore |
Nov 6 2021, 04:13 AM
That looks great - clean as a whistle. Great job. I remember years ago spending hours with a toothbrush and mineral spirts and thinner trying to get the nasty undercoating off the firewall. It was nasty. (IMG:style_emoticons/default/thumb3d.gif) Thx, QM |
Lo-Fi Version | Time is now: 28th April 2024 - 09:33 PM |
