FS: PAG issued Wheel Caps New Uninstalled |
edrotol |
Oct 27 2021, 05:01 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
4 PAG issued for all 4’s 914.361.303.07 PAG certified it complied with Federal safety standards. $175 PayPal plus shipping.
Attached thumbnail(s) |
JeffBowlsby |
Oct 27 2021, 06:39 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Are these the factory original stainless steel caps (wide lip) if so I call dibs pending confirmation, or are these the later factory style with the narrow lips?
A closeup photo in focus would be appreciated. |
L-Jet914 |
Oct 27 2021, 10:05 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Those look like the new ones issues through Porsche Classic or the one's that 914Rubber offer the machined satin aluminum center caps but it's hard to be sure without more in focus picture of the part numbers. Porsche Classic online has the part number as PCG36130307. Or are these the same ones you also have listed for 99 plus shipping? http://www.914world.com/bbs2/index.php?showtopic=356459 Best of luck with the sale.
JeffBowlsby |
Oct 27 2021, 11:02 PM
An online PN search shows these are alum. I’ll pass.
https://cdn4.pelicanparts.com/catalog/image...03-03-SIC_2.jpg |
Jett |
Oct 28 2021, 09:25 AM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
If these are the factory version I bought a set a couple years back, but did not use them.
https://www.sunsetporscheparts.com/oem-part...cap-91436130307 |
914werke |
Oct 28 2021, 10:20 AM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
As Jeff alluded to you can still buy them new, but there is a difference between what you can get nowadays & NOS.
The old ones had a prominent & wider rim/lip they came in a little porsche script box vs the new stock that come in little plastic bags. |
edrotol |
Oct 28 2021, 11:29 AM
Those look like the new ones issues through Porsche Classic or the one's that 914Rubber offer the machined satin aluminum center caps but it's hard to be sure without more in focus picture of the part numbers. Porsche Classic online has the part number as PCG36130307. Or are these the same ones you also have listed for 99 plus shipping? http://www.914world.com/bbs2/index.php?showtopic=356459 Best of luck with the sale. To clear the matter up there is a master box labelled PCG 361.303.07, having 4 cardboard boxes, each labelled with 361.303.07, (no PCG) The master box says assembled in Germany with parts from Taiwan, although there is another part that states made in Germany WE Datum 22.07.2016. Both master and each box have the PAG certification sticker, also labelled Hub Cap Set. These are definitely PAG's boxes and not 914world's. The $99 ones are not the same. One way to see the difference is the PAG's have an inner sticker in each of the caps, if you look at the inside the round etching is larger than the ones from 914world and lasty that same round etching is flatter on the PAG. I have no other information but i can't read German. Thanks all |
JeffBowlsby |
Oct 28 2021, 01:28 PM
Your's look like this right?
TJB/914 |
Oct 28 2021, 02:05 PM
Mid-Engn. Group: Members Posts: 4,327 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Here's a long ago photo of a real German cap and a repo. Mystery (IMG:style_emoticons/default/popcorn[1].gif) Attached thumbnail(s) |
914werke |
Oct 28 2021, 02:12 PM
yup those are the new (stainless) caps, note the rim dimension ~
edrotol |
Oct 28 2021, 02:45 PM
Your's look like this right? Having problem with my iMac. but: My description stands but its not at all like your photo. The big circle on mine is a lot larger than your circle. There is a mystery. I have another set but this time the circle is also larger than yours but now sort of embedded not flat like the rest of the area. I will send photos later but there are 3 different ones in my stack with only one beinglabelled by PAG. |
914werke |
Oct 28 2021, 02:51 PM
Are these the factory original stainless steel caps (wide lip) ? (IMG:style_emoticons/default/mrs.K.gif) |
Oct 28 2021, 02:58 PM
I sold a pair of nos original Porsche caps about 2 years again.
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 PM |
