Quickjack has arrived, should make things easier I hope! |
914Mels |
Oct 28 2021, 04:51 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
After many years of struggling with jacks and stands, I purchased a Quickjack 5000 SLX. Despite Fed Ex's attempts to destroy my new toy, it went together well and works fine. It hits the jack points easily, it comes with a few rubber blocks of different heights to contact the frame. I'm looking to use it to pull the motor and trans, the lift height looks adequate for this. Costco has them on sale now, online only. $100 off for the one I picked out.
Olympic 914 |
Oct 28 2021, 05:19 PM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You are going to Love it.
Justinp71 |
Oct 28 2021, 05:33 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I have had one for a little while now, they are handy. I feel like its similar work to a floor jack if you just had to get half of the car up for say like adjusting the clutch. My car is so low it takes me a bit to get the quick jack where I want it. For my track car it is great because it stores under that better and its really easy to see the jack points. It's also is a must on my audi because they don't have many jack points. They also take up minimal space so that is a big plus for me.
BillJ |
Oct 28 2021, 06:27 PM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
I just got one as well and cant wait to use it on the race car. Plan to change the oil on the diesel cayenne this weekend too with it.
L-Jet914 |
Oct 28 2021, 06:37 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Congrats on the new QuickJack. I purchased the 7000SLX from Costco when they had a $300 off promo which included the light truck/suv lift adapters and wall hangers as a package as I work on other vehicles beside the 914 occasionally so I wanted the flexibility for vehicle weight. Setup was easy. I used some transmission fluid I had on hand from work, and teflon tape instead of the liquid stuff they sent.
Robarabian |
Oct 28 2021, 09:04 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Hey as a point of safety, there should be two other pieces in the box that extend outward from each quickjack. They are meant to stabilize the system in case it rocks. You should never use the system without those items in place.
It can tip over on you and kill you. You're in CA like me.. the earth quakes and shakes at odd times... |
wes |
Oct 28 2021, 09:09 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Very handy! I hung mine on the wall and it takes no space. My only regret is I didn’t buy it before the restoration.
BillJ |
Oct 29 2021, 09:24 AM
Hey as a point of safety, there should be two other pieces in the box that extend outward from each quickjack. They are meant to stabilize the system in case it rocks. You should never use the system without those items in place. It can tip over on you and kill you. You're in CA like me.. the earth quakes and shakes at odd times... What two pieces do you mean? I received two handles meant to be used in moving the jacks but no additional stabilizers... |
914Mels |
Oct 29 2021, 10:15 AM
Hey as a point of safety, there should be two other pieces in the box that extend outward from each quickjack. They are meant to stabilize the system in case it rocks. You should never use the system without those items in place. It can tip over on you and kill you. You're in CA like me.. the earth quakes and shakes at odd times... The sheet that lists all the parts doesn't mention anything about extra supports. The only loose parts are the drag handles to position them. |
Van B |
Oct 29 2021, 10:34 AM
Senior Member Group: Members Posts: 1,587 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Bought mine over a year ago and there was no stabilizer accessory. I think they just make the quick jacks wider.
One recommendation I would make is to order some race ramp wheel cribs and some of the metal high lift attachments for the quick jack. The high lift made dropping the transmission from my 996 possible. Other wise the combined height of the harbor freight transmission jack and the bell housing would've been too much. The wheel cribs are awesome if your car will be in the air for extended time. you can set if on the 12" wheel cribs and move the quickjacks out of the way. Then you can slide under the car from the side rather than just front and rear. |
wes |
Oct 29 2021, 10:36 AM
Hey as a point of safety, there should be two other pieces in the box that extend outward from each quickjack. They are meant to stabilize the system in case it rocks. You should never use the system without those items in place. It can tip over on you and kill you. You're in CA like me.. the earth quakes and shakes at odd times... The sheet that lists all the parts doesn't mention anything about extra supports. The only loose parts are the drag handles to position them. I’ve never heard of this support and definitely didn’t receive them with mine ether. |
914Mels |
Oct 29 2021, 12:39 PM
Bought mine over a year ago and there was no stabilizer accessory. I think they just make the quick jacks wider. One recommendation I would make is to order some race ramp wheel cribs and some of the metal high lift attachments for the quick jack. The high lift made dropping the transmission from my 996 possible. Other wise the combined height of the harbor freight transmission jack and the bell housing would've been too much. The wheel cribs are awesome if your car will be in the air for extended time. you can set if on the 12" wheel cribs and move the quickjacks out of the way. Then you can slide under the car from the side rather than just front and rear. Can you post a picture of the cribs and high lift attachments? Thanks. |
Van B |
Oct 29 2021, 08:42 PM
https://www.raceramps.com/garage-service/cribs/c/cribs/
https://www.quickjack.com/accessories/truck-adapter-kit/ Attached image(s) |
914Mels |
Oct 29 2021, 08:46 PM
Nice!
Van B |
Oct 29 2021, 09:32 PM
I bought two of the 2-piece and two of the 1-piece wheel cribs because my 996 is too low to start with the high lift adapters. Haven’t tried with my 914 yet, but maybe it will be high enough.
If so, then it could save you some $$ in getting to max altitude. |
914Mels |
Oct 29 2021, 10:02 PM
I bought two of the 2-piece and two of the 1-piece wheel cribs because my 996 is too low to start with the high lift adapters. Haven’t tried with my 914 yet, but maybe it will be high enough. If so, then it could save you some $$ in getting to max altitude. Thanks for the info. |
BillJ |
Oct 30 2021, 09:13 AM
Hey as a point of safety, there should be two other pieces in the box that extend outward from each quickjack. They are meant to stabilize the system in case it rocks. You should never use the system without those items in place. It can tip over on you and kill you. You're in CA like me.. the earth quakes and shakes at odd times... What two pieces do you mean? I received two handles meant to be used in moving the jacks but no additional stabilizers... @Robarabian |
jcd914 |
Nov 2 2021, 08:16 PM
I was on the fence and this thread prompted me to look a little closer.
Reading through reviews and their site no stability issues if set up correctly. I watched their set up video, no mention of a stabilizer, maybe older design. I just ordered TL 5000 Quickjack yesterday. I also got a 15% discount code from BendPak for the SEMA show and it saved me about $250. Jim Disclaimer: I have no financial interest BendPak just passing on a discount. Through one of their website use code at checkout: SEMA2021 The code expires on 11/13/2021. |
The Double S |
Nov 7 2021, 10:11 AM
Member Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California |
Congrats on the new QuickJack. I purchased the 7000SLX from Costco when they had a $300 off promo which included the light truck/suv lift adapters and wall hangers as a package as I work on other vehicles beside the 914 occasionally so I wanted the flexibility for vehicle weight. Setup was easy. I used some transmission fluid I had on hand from work, and teflon tape instead of the liquid stuff they sent. Did the same. I didn't regret purchasing from Costco because your able to return them easily in store if there is an issue. Heads up to anyone looking to purchase...They just came out with models that can lift 3" higher. |
914Mels |
Nov 7 2021, 12:55 PM
It got it's first tryout a couple days ago. Engine and transaxle dropped out nicely, felt very secure. I wish I'd gotten them before. Once the alternator, oil leaks, clutch get handled, on to front control arm bushings.
Lo-Fi Version | Time is now: 18th May 2024 - 03:38 PM |
