a new project..., the continuing saga... |
Aaron Cox |
Jul 22 2003, 11:10 PM
well mr. Jimmy Doofus Wong, the PO decided he wanted to put racing harnesses in the car....drilled holes thru the floor pans.....(never installed the harnesses!)
so being a masochist (let the work keep on piling up plz) i need to patch them....and do the POR 15 while in there. so- do i have my buddy weld some metal in there? or just epoxy some crap over the hole? |
Jul 22 2003, 11:18 PM
argh, no epoxy, pleazzze ...
how big are the holes? just install a harness (IMG:style_emoticons/default/smile.gif) fresh air vents? rain water drain? ashtray/cigarette disposal? |
Aaron Cox |
Jul 22 2003, 11:21 PM
1/2 an inch diameter..... what is the best way to take the tar paper stuff off? heat gun? brake cleaner? (IMG:style_emoticons/default/blink.gif)
Jul 22 2003, 11:25 PM
heat gun ...
warm it up (not too much, you don't want it floating around), then just scrape it off, it comes off in big chuncks. then, if you want, use brake cleaner to clean up the glue leftovers ... Andy |
Lawrence |
Jul 23 2003, 06:28 AM
How about some rubber plugs, in case you DO later decide for a harness. A bit of black RTV, and they'll be water-tight.
-Rusty (IMG:style_emoticons/default/smoke.gif) |
TheCabinetmaker |
Jul 23 2003, 07:01 AM
(IMG:style_emoticons/default/agree.gif) with rusty
Aaron Cox |
Jul 23 2003, 09:52 PM
QUOTE(Lawrence @ Jul 23 2003, 05:28 AM) How about some rubber plugs, in case you DO later decide for a harness. A bit of black RTV, and they'll be water-tight. -Rusty (IMG:style_emoticons/default/smoke.gif) i dont think ill ever need harnesses....i wanna do it right and do it ONCE. i need to install carpet and a console, so i never want to see the floor pans from the inside again. so, rubber plugs are not the long term solution |
Jul 23 2003, 09:59 PM
QUOTE(acox914 @ Jul 23 2003, 08:52 PM) i dont think ill ever need harnesses....i wanna do it right and do it ONCE. i need to install carpet and a console, so i never want to see the floor pans from the inside again. so, rubber plugs are not the long term solution then weld em up ... |
Aaron Cox |
Jul 23 2003, 10:01 PM
will the undercoatin burn off from the heat if the welder
Jul 23 2003, 10:03 PM
QUOTE(acox914 @ Jul 23 2003, 09:01 PM) will the undercoatin burn off from the heat if the welder yepp, undercoating and sound-proof tar stuff WILL burn ... Andy |
Lo-Fi Version | Time is now: 14th May 2024 - 05:12 AM |
