914 boxster 6 speed conversion, Starting a resto mod 914 |
74forsche |
Oct 31 2021, 10:21 AM
Newbie Group: Members Posts: 49 Joined: 6-November 20 From: castle rock washinton Member No.: 24,848 Region Association: Pacific Northwest |
So I'm in process of collecting parts and info for my 914 restomod. Going with a sbf with boxster s 6 speed and 911 suspension/brakes.
One of the details I'm trying to sort out is the church actuation for the boxster s gear box. Anyone have a good source for what pedal cluster and hydraulic bits work best? I will be using a manual throttle cable. |
brant |
Oct 31 2021, 11:04 AM
Ford?
Andyrew |
Oct 31 2021, 11:53 AM
Either go with a tilton/wilwood floor mount or modify your existing system with a hydraulic clutch. Someone makes a bracket for mounting a master through the body but its not that complicated.
ClayPerrine |
Oct 31 2021, 02:06 PM
Here is a link to my build....
http://www.914world.com/bbs2/index.php?sho...9084&st=120 That page has how I put a clutch master cylinder on the factory 914 pedal box. There is a later page that has the mod that makes it more reliable. Clay |
yellowporky |
Oct 31 2021, 02:08 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
993 pedal assembly
ClayPerrine |
Oct 31 2021, 02:12 PM
yellowporky |
Oct 31 2021, 02:16 PM
Sorry, i guess if forgot that my car has a 993 floor pan in that section. From what i remember they looked very similar.
ClayPerrine |
Oct 31 2021, 02:18 PM
This page has pictures of the later version of the pedal box.
http://www.914world.com/bbs2/index.php?sho...9084&st=240 Clay |
74forsche |
Oct 31 2021, 08:31 PM
74forsche |
Oct 31 2021, 08:32 PM
Here is a link to my build.... http://www.914world.com/bbs2/index.php?sho...9084&st=120 That page has how I put a clutch master cylinder on the factory 914 pedal box. There is a later page that has the mod that makes it more reliable. Clay Nice! Boxster slave and master cylinders? |
djway |
Oct 31 2021, 09:20 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
tygaboy |
Oct 31 2021, 09:52 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
@djway - Looks like you need your fire wall moved forward... I know a guy who could help you. (IMG:style_emoticons/default/lol-2.gif) |
AZBanks |
Oct 31 2021, 11:01 PM
Senior Member Group: Members Posts: 1,062 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Looks like you need your fire wall moved forward... I know a guy who could help you. (IMG:style_emoticons/default/lol-2.gif) When are we going to see some new content on the Racerbenz on GRMS.com? |
ClayPerrine |
Nov 1 2021, 05:34 AM
Here is a link to my build.... http://www.914world.com/bbs2/index.php?sho...9084&st=120 That page has how I put a clutch master cylinder on the factory 914 pedal box. There is a later page that has the mod that makes it more reliable. Clay Nice! Boxster slave and master cylinders? I built it with a 964 master and a Cayman slave. There is no way to mount a Cayman master on the 914 pedal box. Now it has a Cayman slave, and a Wilwood Master. The Wilwood master was necessary to get the correct bore size to match the Cayman slave. The reservoir is from a 924S. Clay |
74forsche |
Nov 1 2021, 08:52 AM
74forsche |
Nov 1 2021, 08:53 AM
[quote name='ClayPerrine' date='Nov 1 2021, 06:34 AM' post='2956747']
[quote name='74forsche' post='2956695' date='Oct 31 2021, 09:32 PM'] [quote name='ClayPerrine' post='2956577' date='Oct 31 2021, 03:06 PM'] Here is a link to my build.... http://www.914world.com/bbs2/index.php?sho...9084&st=120 That page has how I put a clutch master cylinder on the factory 914 pedal box. There is a later page that has the mod that makes it more reliable. Clay [/quote] Nice! Boxster slave and master cylinders? [/quote] I built it with a 964 master and a Cayman slave. There is no way to mount a Cayman master on the 914 pedal box. Now it has a Cayman slave, and a Wilwood Master. The Wilwood master was necessary to get the correct bore size to match the Cayman slave. The reservoir is from a 924S. Clay Year of 964 master? |
ClayPerrine |
Nov 1 2021, 09:21 AM
[quote name='74forsche' date='Nov 1 2021, 09:53 AM' post='2956786']
[quote name='ClayPerrine' date='Nov 1 2021, 06:34 AM' post='2956747'] [quote name='74forsche' post='2956695' date='Oct 31 2021, 09:32 PM'] [quote name='ClayPerrine' post='2956577' date='Oct 31 2021, 03:06 PM'] Here is a link to my build.... http://www.914world.com/bbs2/index.php?sho...9084&st=120 That page has how I put a clutch master cylinder on the factory 914 pedal box. There is a later page that has the mod that makes it more reliable. Clay [/quote] Nice! Boxster slave and master cylinders? [/quote] I built it with a 964 master and a Cayman slave. There is no way to mount a Cayman master on the 914 pedal box. Now it has a Cayman slave, and a Wilwood Master. The Wilwood master was necessary to get the correct bore size to match the Cayman slave. The reservoir is from a 924S. Clay Year of 964 master? [/quote] 1991. But it doesn't match the Cayman slave cylinder. So it won't disengage the clutch. Clay |
Chris914n6 |
Nov 1 2021, 11:14 AM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
74forsche |
Nov 3 2021, 09:57 PM
We don't see sbf swaps because they are huge and don't fit. You might want to test fit before committing to the pricey adapter kit. Not true. 302 ford with coil on plug and remote mount water pump is shorter than ls....the ls conversions move the transmission back...to clear the fire wall....which is what I'm going to do. Additionally I'm moving the mount for the rear trailing arm back to achieve appropriate cv angle of operation.... |
djway |
Nov 3 2021, 10:02 PM
@djway - Looks like you need your fire wall moved forward... I know a guy who could help you. (IMG:style_emoticons/default/lol-2.gif) @tygaboy Actually it looks like a remote water pump and distributor less ignition should squeeze in OK. I just want to get to drive a Pord (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 09:03 AM |
