914 boxster 6 speed conversion, Starting a resto mod 914 |
Chris914n6 |
Nov 4 2021, 12:25 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
We don't see sbf swaps because they are huge and don't fit. You might want to test fit before committing to the pricey adapter kit. Not true. 302 ford with coil on plug and remote mount water pump is shorter than ls....the ls conversions move the transmission back...to clear the fire wall....which is what I'm going to do. Additionally I'm moving the mount for the rear trailing arm back to achieve appropriate cv angle of operation.... Now that I think about it more, the problem was the front mount dizzy in the drivers shoulder. You should be good with 100mm cv's, it's not the angle that's the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1636007128.1.jpg) |
Retroracer |
Nov 4 2021, 10:06 AM
Senior Member Group: Members Posts: 614 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
..or maybe a Forsche. Easier to modify the trunk script letters.... (IMG:style_emoticons/default/smile.gif)
- Tony |
74forsche |
Nov 17 2021, 11:43 PM
Newbie Group: Members Posts: 49 Joined: 6-November 20 From: castle rock washinton Member No.: 24,848 Region Association: Pacific Northwest |
We don't see sbf swaps because they are huge and don't fit. You might want to test fit before committing to the pricey adapter kit. Not true. 302 ford with coil on plug and remote mount water pump is shorter than ls....the ls conversions move the transmission back...to clear the fire wall....which is what I'm going to do. Additionally I'm moving the mount for the rear trailing arm back to achieve appropriate cv angle of operation.... Now that I think about it more, the problem was the front mount dizzy in the drivers shoulder. You should be good with 100mm cv's, it's not the angle that's the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1636007128.1.jpg) So I am not up on the cv joint tech.....which ones tolerate more angle? |
74forsche |
Dec 11 2021, 10:12 PM
My Kep sbf to boxster s adapter arrived. Its barely 1 inch thick. Should make fitting the small ford V8 even easier.
Attached thumbnail(s) |
74forsche |
Dec 11 2021, 10:15 PM
Here is the matching flywheel...pretty impressed with KEP parts. Hopefully they fit as good as they look
The Double S |
Dec 12 2021, 11:05 AM
Member Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California |
74forsche |
Dec 12 2021, 07:45 PM
Here is the matching flywheel...pretty impressed with KEP parts. Hopefully they fit as good as they look Looking good. What made you decide to go with KEP over some of the other options? What axles are you planning on using? Kep has a great reputation. Not aware of anyone else that does better. With boxster s 6 speed i am leaning toward renegades axles. |
Maltese Falcon |
Dec 13 2021, 10:24 PM
Advanced Member Group: Members Posts: 4,673 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
We don't see sbf swaps because they are huge and don't fit. You might want to test fit before committing to the pricey adapter kit. Not true. 302 ford with coil on plug and remote mount water pump is shorter than ls....the ls conversions move the transmission back...to clear the fire wall....which is what I'm going to do. Additionally I'm moving the mount for the rear trailing arm back to achieve appropriate cv angle of operation.... Now that I think about it more, the problem was the front mount dizzy in the drivers shoulder. You should be good with 100mm cv's, it's not the angle that's the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1636007128.1.jpg) So I am not up on the cv joint tech.....which ones tolerate more angle? Check out the specific prepped ProAm 930 CV joints, good for deep plunging angle use; from McKenzie.com We assembled ours on to Sway-Away 300m alloy floating style axles, and lubed with Krytox brand grease. Going into use on our v8 build, which has non-stock angles. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:03 AM |
