Tinware writing, Was this on all cars…?? |
Clubsport32 |
Nov 7 2021, 01:13 AM
Newbie Group: Members Posts: 7 Joined: 21-January 20 From: United Kingdom Member No.: 23,849 Region Association: None |
Hi All
Have seen this on an unrestored car…does anybody have anymore details…? I assume the 022 refers to the 1.7L but what about the other number? Any insight would be appreciated…thanks Andy Attached thumbnail(s) |
wonkipop |
Nov 14 2021, 12:33 AM
Advanced Member Group: Members Posts: 4,283 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
ps
@JeffBowlsby . i'm still looking at that factory engine prod line photo. and thats 914 2.0 engines those boys are making. you can tell from the throttle body. don't think any VW engines got that throttle body? not even 2.0 L bus motors, pretty sure they had the sideways throttle bodies. i know they are not photos of guys making 912E motors. they had things on the fan castings to hold smog pumps. what are they doing with an arse dragger exhaust system hooked up? |
JeffBowlsby |
Nov 14 2021, 09:22 AM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
ps @JeffBowlsby . i'm still looking at that factory engine prod line photo. and thats 914 2.0 engines those boys are making. you can tell from the throttle body. don't think any VW engines got that throttle body? not even 2.0 L bus motors, pretty sure they had the sideways throttle bodies. i know they are not photos of guys making 912E motors. they had things on the fan castings to hold smog pumps. what are they doing with an arse dragger exhaust system hooked up? I have the same questions, in sum, I dont know. Its not 912E, exhaust looks more 411/412/bus wit its passenger side exhaust tip. Its D-Jet FI (ECU connectors visible on several engines). The stampings format on the left and right side of the tin appear to be consistent with 1973-74 2.0L GA code engines (see below) but the stampings are are illegible. The engine tin profile in plan appears to be 914 but could it be something else? The air cleaner bracket appears to be 914 2.0L. Attached image(s) |
Lo-Fi Version | Time is now: 11th May 2024 - 06:23 AM |
