Gas tank differences |
partwerks |
Nov 7 2021, 08:25 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Other than the bracket for the charcoal canister to mount to, is the general shape/size the same on the 1974, compared to the 1975?
My 75 tank doesn't have a mounting bracket for the canister. To say it differently, will the 1974, fit into the 1975? |
bdstone914 |
Nov 7 2021, 09:14 PM
Other than the bracket for the charcoal canister to mount to, is the general shape/size the same on the 1974, compared to the 1975? My 75 tank doesn't have a mounting bracket for the canister. To say it differently, will the 1974, fit into the 1975? If you use the 75 tank with the expansion tank , filler neck, and cap it will fit. Late 74 had the steel expansion tank and charcoal canister in the engine compartment. You will have to adapt one of the vapor lines in the rocker panel to route the expansion tank fumes to the canister in the engine bay. |
Steve |
Nov 7 2021, 09:28 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
All the tanks will fit in all the 914 years. The only differences is the expansion tank and charcoal canister mounts. The early expansion tank was metal with a metal gas cap. Later expansion tanks are plastic with a plastic gas cap.
And what Bruce said. |
partwerks |
Nov 7 2021, 09:41 PM
Maybe the 74 that is not installed, didn't come out of a 74? It came from a storage stash, so I can't say for sure, but there is a bracket for the canister on the tank. It has the steel expansion chamber, and steel gas cap, and plastic carbon canister.
JeffBowlsby |
Nov 8 2021, 06:23 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It would be really helpful if some of you with several different tanks, post comparison photos of the differences, including the new Dansk and AA tanks. Include close-ups of the different brackets and connection points on each different tank.
Are there 2 or three different tanks? |
Steve |
Nov 8 2021, 06:31 PM
It would be really helpful if some of you with several different tanks, post comparison photos of the differences, including the new Dansk tanks. Include close-ups of the different brackets and connection points on each different tank. Are there 2 different tanks? Is the Dansk tank universal for all years or is it early or late? I understand that the expansion tank was the same up to the late 1974 change to a plastic expansion tank, and not sure if those two tanks mount the same. The other change would be the charcoal canister mount conditions. Dansk used to sell only one tank that was totally wrong. Some of those tanks are still out there. Dr. 914 straightened them out and now they sell both versions (early and late). |
partwerks |
Nov 8 2021, 11:01 PM
Was there just the plastic carbon canister type, and if so, what years?
Lo-Fi Version | Time is now: 17th May 2024 - 04:37 PM |
