Shift Knob - They keep breaking |
VaccaRabite |
Nov 14 2021, 07:21 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The hammer and 2x4 is the same way I remove knobs. And removal is why I started using a larger Delrin bearing surface so the wood would not get marred on removal for the ones I make (made - since its been a few years since I've done a run.)
Zach |
Mikey914 |
Nov 14 2021, 11:07 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The plastic should not break. Its that simple.
We machine ours out of delrin and have the option to add a set screw that Id recommend. About to do another run now. Not as cheap as Dansk, but you get what you pay for. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:05 PM |
