Question On Bilstein Front Shocks, B6 Yellow Gas |
914Sixer |
Nov 10 2021, 02:55 PM
I have a pair I took off the NOLA parts car. They moved up and down fine on car. Got them out and did compression test. They only go down about 3/4 of the way. About 4 " does not compress. Been so long since I played with these shocks, not sure IF that is correct. I am going to put them up for sale IF good.
ctc911ctc |
Nov 10 2021, 03:05 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I am in the midst of changing mine - which way do we go?
Steve |
Nov 10 2021, 03:18 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have a pair I took off the NOLA parts car. They moved up and down fine on car. Got them out and did compression test. They only go down about 3/4 of the way. About 4 " does not compress. Been so long since I played with these shocks, not sure IF that is correct. I am going to put them up for sale IF good. My Bilsteins went bad and Patrick Motor sports show me how easy it was to push down on it, compared to a new one. However even the bad one went back up, just super easy to collapse it. |
914Sixer |
Nov 10 2021, 03:35 PM
Let me try again. Shocks are working fine and pop right out They just do not collapse to the top.
Shivers |
Nov 10 2021, 05:13 PM
Senior Member Group: Members Posts: 2,378 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Van B |
Nov 10 2021, 08:04 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Sounds about like full range to me. Iām sure 4ā on the shock or strut is 6ā or so at the wheel
Lo-Fi Version | Time is now: 17th May 2024 - 04:54 PM |
