FS: 1973 -6 GT Conversion |
roblav1 |
Nov 12 2021, 02:01 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
NLFS
A man has to know his limitations! Mine is impatience. |
roblav1 |
Dec 28 2021, 09:26 PM
Fuel pump toggle switch now installed on dash. Front caster re-set (decreased it). Installed new Nardi wood steering wheel. The Momo to Nardi adapter needed a slight bit of material removed in the lathe. Currently working the ventilation blower and fuel gauge wiring. The ventilation blower switch seems to alter the fan speed through resistance to ground rather than 12V+. The fuel gauge was working, but now reads full all the time. Getting there! 16AN oil hose inlet and slight alterations for clearance on Ben's heat exchangers is up next.
mmascari |
Dec 29 2021, 12:01 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Fuel pump toggle switch now installed on dash. Front caster re-set (decreased it). Installed new Nardi wood steering wheel. The Momo to Nardi adapter needed a slight bit of material removed in the lathe. Currently working the ventilation blower and fuel gauge wiring. The ventilation blower switch seems to alter the fan speed through resistance to ground rather than 12V+. The fuel gauge was working, but now reads full all the time. Getting there! 16AN oil hose inlet and slight alterations for clearance on Ben's heat exchangers is up next. Share more pics. Looks awesome. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:31 PM |
