lots of motor parts, for sale |
brant |
Nov 22 2021, 10:48 AM
914 Wizard Group: Members Posts: 11,619 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
windage tray. This came from a 1975 1.8
I "believe" it will also fit the 2.0 motors I'm not sure if this is still accurate.. but I remember that at the time I was building... the tray seals did not come in the gasket kit. So I'm including a set of Used... tray seals. just in case. $40 + actual shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 11:12 AM
Taco Plate with cover and 2 bolts.
the sender is bad... broken but I found a new sender for sale on Pelican Link to replacement sender not powder coated. but very useable I believe the wire holder is necessary for the sending wire, and included $75 + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 11:15 AM
this is an extra cover(stock) I have for a taco plate
$ 7 + actual shipping if you need one. SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 11:17 AM
non stock taco plate
I just bought this a few weeks ago and wish I had not. someone added a temp sender to a stock taco plate (originally designed for no sender) should work not stock my mistake for buying it $10 + actual shipping if anyone wants to give it a try Attached thumbnail(s) |
brant |
Nov 22 2021, 11:21 AM
a stock oil strainer... with mesh, cover, and special expensive nut
all straight and useable. $10 + actual shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 11:24 AM
4 cylinder dip sticks
used, original plating not fresh. but in good condition $20 each plus actual shipping. Attached thumbnail(s) |
brant |
Nov 22 2021, 11:32 AM
front cooling fan mounting hub
not sure what to call this $12 + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 11:35 AM
rubber cooling fan plug
goes on the fan center for early cars $2 plus actual shipping (I'm hoping to combine some items.. making these small parts cheap) Attached thumbnail(s) |
brant |
Nov 22 2021, 11:36 AM
timing cover on the fan shroud
$1 +actual shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 11:39 AM
this one is hard to find.
I hope 914 rubber makes them in the future this is the rubber cover that goes on the flywheel hole (back of the motor case) $5 + actual shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 11:40 AM
2 fuel injector holding rings
Free to someone that needs them + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 11:57 AM
4 cylinder oil cooler.
so I took this off of a running motor its not full of shrapnel and the motor was not blown up $25 + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 11:58 AM
more cooler pictures
and the special thick washers (factory) are included. Attached thumbnail(s) |
brant |
Nov 22 2021, 12:07 PM
one extra piece (out of the 3 stock pieces) from a cooler mounting bracket
if you need one.. .this is free + shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 12:20 PM
Push rod tubes
and stock push rods not plated not perfect I recycled the ugly ones.. a few of these have minor blemishes on the tubes the rods are all free of wear and scuff wear marks there are 10 stock rods and 6 tubes $20 + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 12:23 PM
Distributor clamp complete with long nut
I am pretty sure this would fit all years of 4 cylinder $5 + actual shipping Attached thumbnail(s) |
brant |
Nov 22 2021, 12:25 PM
Thermostat rod spring clip
I believe there are 2 when the flappers are installed I wish I had included these with the flappers I sold previously. if you need one or two let me know Free + shipping SOLD Attached thumbnail(s) |
brant |
Nov 22 2021, 12:27 PM
windage gasket set
these may be trash... I don't know if they are sold new with gasket kits these days I have an extra set of used that I kept when new was not available free + shipping for the red rubber gaskets I see the case bolt plastic washers are in this picture those will go with the case bolts Attached thumbnail(s) |
brant |
Nov 22 2021, 12:31 PM
4 cylinder case bolts
extras.. and with a used set of plastic anti rattle holders $5 + actual shipping Attached thumbnail(s) |
autopro |
Nov 22 2021, 05:23 PM
Member Group: Members Posts: 306 Joined: 14-January 18 From: San Diego / Tijuana Member No.: 21,797 Region Association: Southern California |
Hi Brant, I would like to get the Flywheel hole cover, Timing cover, oil strainer mesh, cover and nut from you please.
Shipping would be to 91977 San Diego, CA. Thanks, Pedro |
Lo-Fi Version | Time is now: 4th May 2024 - 02:03 PM |
