Swiveling shift lever |
emerygt350 |
Nov 23 2021, 08:13 AM
Advanced Member Group: Members Posts: 2,126 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
My stick swivels clockwise if pushed hard trying to got into reverse or first. If you swivel it back it kinda holds into a better position. If you are real nice to it this doesn't happen. Suggestions? It moves maybe an inch to the left. Maybe 15 degrees.
Shivers |
Nov 23 2021, 08:43 AM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
If I'm reading this correctly, the rod is held into the ball at the bottom with adhesive. Epoxy. I had to separate the pieces to install a short shift. Heat the lower piece with a torch and it will come apart. Clean both pieces and JB weld together.
Superhawk996 |
Nov 23 2021, 09:21 AM
914 Guru Group: Members Posts: 5,870 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If I'm reading this correctly, the rod is held into the ball at the bottom with adhesive. Epoxy. I had to separate the pieces to install a short shift. Heat the lower piece with a torch and it will come apart. Clean both pieces and JB weld together. Ha . . . Learned something new today. I had assumed the ball was machined and a press fit to shift lever. Just cleaned grease off a shift lever and sure enough, it looks like some adhesive is there at the top of the ball. (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 08:48 PM |
