Swiveling shift lever |
emerygt350 |
Nov 23 2021, 08:13 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
My stick swivels clockwise if pushed hard trying to got into reverse or first. If you swivel it back it kinda holds into a better position. If you are real nice to it this doesn't happen. Suggestions? It moves maybe an inch to the left. Maybe 15 degrees.
Shivers |
Nov 23 2021, 08:43 AM
Senior Member Group: Members Posts: 2,368 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
If I'm reading this correctly, the rod is held into the ball at the bottom with adhesive. Epoxy. I had to separate the pieces to install a short shift. Heat the lower piece with a torch and it will come apart. Clean both pieces and JB weld together.
Lo-Fi Version | Time is now: 8th May 2024 - 03:26 PM |
