Swiveling shift lever |
emerygt350 |
Nov 23 2021, 08:13 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
My stick swivels clockwise if pushed hard trying to got into reverse or first. If you swivel it back it kinda holds into a better position. If you are real nice to it this doesn't happen. Suggestions? It moves maybe an inch to the left. Maybe 15 degrees.
930cabman |
Nov 24 2021, 06:41 PM
Advanced Member Group: Members Posts: 3,017 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate?
toolguy |
Nov 25 2021, 09:45 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
930cabman |
Nov 25 2021, 05:22 PM
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate? You risk going into 1st when doing an aggressive 4th to 3rd downshift Don't ask how i know but it will happen. . . Thanks. I have been considering this for a while, and I personally never "aggressively shift" any of my sporting machines. Even when new, these gearboxes required a soft touch. just my .02 |
ChrisFoley |
Nov 25 2021, 07:05 PM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate? You risk going into 1st when doing an aggressive 4th to 3rd downshift Don't ask how i know but it will happen. . . Thanks. I have been considering this for a while, and I personally never "aggressively shift" any of my sporting machines. Even when new, these gearboxes required a soft touch. just my .02 Rennshift is spring-loaded both left and right, and the spring pressure can be adjusted to your preference. |
Lo-Fi Version | Time is now: 8th May 2024 - 07:16 AM |
