Fuel pump making noises (I think), Should I replace ASAP? |
DC_neun_vierzehn |
Nov 28 2021, 06:16 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I have a '73 2.0 (the fuel pump was relocated to the front by the PO).
Lately I've been hearing some noises coming from behind dash/frunk area. It sounds like a pulsating strained noise (almost sounds like a duck). The noise isn't constant. I don't recall hearing it when I start up, but I definitely hear it when I pull up to a red light or get off the highway. I feel like I've narrowed it down to the fuel pump because there's nothing else on when I hear the noise (fresh air box or heat fan in rear). My question(s): Do fuel pumps make noises like this before they're about to die? Could it be something else? Here are some pics ... Attached thumbnail(s) |
ClayPerrine |
Dec 4 2021, 09:03 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just an additional thought...
I always put a fuel filter in the engine compartment to protect the injectors. If you use one designed for fuel injection systems, then it is readily accessible and easy to change. I use the fuel filter for a 1988 Nissan Maxima. Clay |
Lo-Fi Version | Time is now: 18th May 2024 - 09:44 PM |
