Whats the best tool you ever acquired |
914werke |
Dec 3 2021, 02:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Was thinking about this recently ...
Based on how much you paid for it, if anything, how long you've had it & how often you've use it. Hopefully it should be more than a open end wrench or pair of vice grips (IMG:style_emoticons/default/biggrin.gif) Mine was a Hobart handler 130. Bought it used with lrg bottle for $99. MANY yrs ago & its still going strong use it almost daily. (IMG:style_emoticons/default/aktion035.gif) |
Spoke |
Dec 4 2021, 08:10 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Dremel motor tool.
I've used that tool on just about everything. The one job that comes to mind where the Dremel saved the day was removing the rear wheel bearing races from my '86 930. Procedure was to heat heat heat up the swing arm then pound the race out. No luck. Same with the race on the hub using a bearing splitter. Spent 2 days trying to get the races off. Then decided to slice the races with a cutoff wheel. 10 minutes later all the races were off. |
Lo-Fi Version | Time is now: 13th May 2024 - 01:55 AM |
