Whats the best tool you ever acquired |
914werke |
Dec 3 2021, 02:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Was thinking about this recently ...
Based on how much you paid for it, if anything, how long you've had it & how often you've use it. Hopefully it should be more than a open end wrench or pair of vice grips (IMG:style_emoticons/default/biggrin.gif) Mine was a Hobart handler 130. Bought it used with lrg bottle for $99. MANY yrs ago & its still going strong use it almost daily. (IMG:style_emoticons/default/aktion035.gif) |
pfreiburger |
Dec 5 2021, 01:03 AM
Member Group: Members Posts: 110 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None |
I really like my Evolution 14” metal cut off saw, which I have owned it for about 3 years. Unlike most chop saws it uses a toothed rather than abrasive blade. The cuts are cleaner and the saw is cleaner in operation, producing MUCH less dust than an abrasive blade chop saw – actually more chips than anything. The only downside is that the blades are expensive ($80 & up) but they promise a 1000 cut life – in my experience that is probably accurate as I am still on my first blade and it will cut ½” stock clean & quick. The newer versions have detail refinements and are even better. I would buy one again for sure.
Lo-Fi Version | Time is now: 12th May 2024 - 07:13 AM |
