Motor oil shelf life, 2+ cases of VR-1, unopened bottles |
anderssj |
Dec 4 2021, 09:43 AM
Dog is my copilot... Group: Members Posts: 1,652 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
I bought three cases of Valvoline VR-1 20w50 about 18 months ago, back when it was cheap(er). Given the number of miles I put on the teener in a given year, the remaining 2 cases will probably last me another 3 years or so. Any problem using oil that is 4 to 5 years old if the bottles are unopened?
BTW, I read a number of the various articles on the web, but thought I would get better gouge from the experts here... (IMG:style_emoticons/default/pray.gif) Thanks in advance! |
Superhawk996 |
Dec 4 2021, 10:12 AM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Sort of depends whether or not your the sort of guy that won't eat food that is past its "expiration date".
(IMG:style_emoticons/default/laugh.gif) |
Shivers |
Dec 4 2021, 10:16 AM
Senior Member Group: Members Posts: 2,354 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
It's a couple hundred million years old already. I don't think a couple years will be a big deal.
ClayPerrine |
Dec 4 2021, 10:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,415 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It's a couple hundred million years old already. I don't think a couple years will be a big deal. (IMG:style_emoticons/default/agree.gif) |
jcd914 |
Dec 4 2021, 02:47 PM
I would not worry about it with todays oils and additives.
BUT I actually do have personal bad and dumb experience with very old oil I should not have used in my truck. 1990-ish I briefly came to own a 1979 Pinto, whole other story that's better with (IMG:style_emoticons/default/beerchug.gif) But that Pinto had a half a case of Texaco Havoline motor oil, old-style cans that require a spout punched in. I knew it was old oil but used it to change the oil in my 1980 Datsun truck and after a several weeks of use and then sitting a week or so it would not start, cranked slow. Low battery, I assumed and put the charger on it, an hour later I try again and get the same thing. I then proceeded to guess my way through cleaning battery cables, ground connections, jumping from van, up to concluding the starter was bad and replacing it. Before I got out my amp meter and read 370 amp starter draw and realized the engine was the problem! The old oil had turned to almost a jelly, it was so thick it drained so slow I put a heater under the engine to get the stuff out, N CA area it was not cold. So embarrassing note here, at the time I was a Porsche dealership tech. Test don't guess! Jim |
anderssj |
Dec 4 2021, 04:20 PM
Thanks all! Appreciate the responses. The oil is stored in my garage (in VA), so should be ok. Maybe I can sneak it into a climate-controlled closet upstairs in the house
(IMG:style_emoticons/default/biggrin.gif) |
rgalla9146 |
Dec 4 2021, 06:51 PM
It's a couple hundred million years old already. I don't think a couple years will be a big deal. (IMG:style_emoticons/default/agree.gif) I said those exact words to Ray Mital more than once. The things added by sustained exposure to the internal combustion environment are another story. |
PatMc |
Dec 5 2021, 06:40 AM
Member Group: Members Posts: 119 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
I would have no issues using it until it's started "canning". Canning is when the bottle looks like you pulled a vacuum on it and it's somewhat collapsed...that typically means that a significant amount of atmosphere has permeated the package and started to affect (oxidize, or something else) the product. If the bottle looks normal and there's no "use by" date it on....shake it up some (sometimes fine solids will fall out of suspension over time) and run it.
I apply this rule to just about everything in a bottle. |
infraredcalvin |
Dec 5 2021, 11:33 AM
Distracted Member Group: Members Posts: 1,509 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
@PatMc Another Pat Mc (short for McCabe, what’s yours?) here…. I see them on the flaps shelves with “canning” sometimes…
Mobil 1 says 5 years for its conventional for synthetic…. Others as you may have read state around 5 years conventional 7 for synthetic. |
930cabman |
Dec 5 2021, 12:43 PM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Sort of depends whether or not your the sort of guy that won't eat food that is past its "expiration date". (IMG:style_emoticons/default/laugh.gif) Or not comply with the "5 second rule" |
Van B |
Dec 5 2021, 06:14 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
I would have no issues using it until it's started "canning". Canning is when the bottle looks like you pulled a vacuum on it and it's somewhat collapsed...that typically means that a significant amount of atmosphere has permeated the package and started to affect (oxidize, or something else) the product. If the bottle looks normal and there's no "use by" date it on....shake it up some (sometimes fine solids will fall out of suspension over time) and run it. I apply this rule to just about everything in a bottle. (IMG:style_emoticons/default/agree.gif) Plus, you’ll need to give it the ole paint can shake when you do finally use it. Some of the additives will settle over time. I actually do the shaky shake on every bottle. But, there’s probably medication I could take for that. |
930cabman |
Dec 6 2021, 02:48 PM
I would have no issues using it until it's started "canning". Canning is when the bottle looks like you pulled a vacuum on it and it's somewhat collapsed...that typically means that a significant amount of atmosphere has permeated the package and started to affect (oxidize, or something else) the product. If the bottle looks normal and there's no "use by" date it on....shake it up some (sometimes fine solids will fall out of suspension over time) and run it. I apply this rule to just about everything in a bottle. (IMG:style_emoticons/default/agree.gif) Plus, you’ll need to give it the ole paint can shake when you do finally use it. Some of the additives will settle over time. I actually do the shaky shake on every bottle. But, there’s probably medication I could take for that. When you find the medication, please share as many of us could use it |
73-914 |
Dec 6 2021, 03:36 PM
Senior Member Group: Members Posts: 572 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
I would have no issues using it until it's started "canning". Canning is when the bottle looks like you pulled a vacuum on it and it's somewhat collapsed...that typically means that a significant amount of atmosphere has permeated the package and started to affect (oxidize, or something else) the product. If the bottle looks normal and there's no "use by" date it on....shake it up some (sometimes fine solids will fall out of suspension over time) and run it. I apply this rule to just about everything in a bottle. (IMG:style_emoticons/default/agree.gif) Plus, you’ll need to give it the ole paint can shake when you do finally use it. Some of the additives will settle over time. I actually do the shaky shake on every bottle. But, there’s probably medication I could take for that. When you find the medication, please share as many of us could use it It's called "Applejack" |
Lo-Fi Version | Time is now: 26th April 2024 - 02:52 PM |
