I would not worry about it with todays oils and additives.
BUT I actually do have personal bad and dumb experience with very old oil I should not have used in my truck.
1990-ish I briefly came to own a 1979 Pinto, whole other story that's better with
But that Pinto had a half a case of Texaco Havoline motor oil, old-style cans that require a spout punched in.
I knew it was old oil but used it to change the oil in my 1980 Datsun truck and after a several weeks of use and then sitting a week or so it would not start, cranked slow.
Low battery, I assumed and put the charger on it, an hour later I try again and get the same thing.
I then proceeded to guess my way through cleaning battery cables, ground connections, jumping from van, up to concluding the starter was bad and replacing it.
Before I got out my amp meter and read 370 amp starter draw and realized the engine was the problem! The old oil had turned to almost a jelly, it was so thick it drained so slow I put a heater under the engine to get the stuff out, N CA area it was not cold.
So embarrassing note here, at the time I was a Porsche dealership tech.
Test don't guess!
Jim
