access to spark plugs, novice question |
dlindzey |
Dec 4 2021, 01:51 PM
repeat offender Group: Members Posts: 33 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
is it necessary to remove the black metal shroud on top of the engine to get access to and pull spark plugs and check compression? it seems like dark holes and bad angles for the work to be done.
Shivers |
Dec 4 2021, 05:20 PM
Senior Member Group: Members Posts: 2,390 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I have no problem with carbs. I use a piece of the cardboard box the plugs come in, wrap around enough on the plug so the plug sticks in the socket. Duct tape the socket to the extension. With the formed cardboard in the socket, reach down and slip it over the plug loosen it up and pull it out.
Lo-Fi Version | Time is now: 22nd May 2024 - 01:02 AM |
