windshield to dash seal, question |
hndyhrr |
Dec 8 2021, 07:13 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Good evening,
Pumpkin is a 1970. I have dash out. Question is can I put the windshield to dash seal in before I put the dash in or should it wait til after dash is installed. Thanks Renee |
partwerks |
Dec 8 2021, 07:20 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
IIRC, the one I'm getting from 914 rubber, is stiffer, and can be put in with WS in.
Anything else, you may need to I had always read? |
hndyhrr |
Dec 8 2021, 08:20 PM
mmichalik |
Dec 8 2021, 08:56 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
you would be able to get to it a lot easier with the dash out but, I believe it would be easier.
Glass out would be the easiest though, I know that's not an option here. |
iankarr |
Dec 8 2021, 09:39 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The challenge is that the seal sits on top of the installed dash. If you absolutely can't take the glass out, I'd probably opt for putting the seal in AFTER the dash. Probably easier to push in on the pinch weld than to fit the dash under.
Mikey914 |
Dec 8 2021, 11:20 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The seal was designed to install without removing glass or windshield.
So, I would do it after the dash was installed. That way its installed laid flat on it. |
hndyhrr |
Dec 8 2021, 11:49 PM
Thank you guys!
Lo-Fi Version | Time is now: 18th May 2024 - 03:03 PM |
