hndyhrr
Dec 8 2021, 07:13 PM
Good evening,
Pumpkin is a 1970. I have dash out. Question is can I put the windshield to dash seal in before I put the dash in or should it wait til after dash is installed.
Thanks
Renee
partwerks
Dec 8 2021, 07:20 PM
IIRC, the one I'm getting from 914 rubber, is stiffer, and can be put in with WS in.
Anything else, you may need to I had always read?
hndyhrr
Dec 8 2021, 08:20 PM
QUOTE(partwerks @ Dec 8 2021, 05:20 PM)
WS is in, Dash is out. put seal in before or after dash re install?
mmichalik
Dec 8 2021, 08:56 PM
you would be able to get to it a lot easier with the dash out but, I believe it would be easier.
Glass out would be the easiest though, I know that's not an option here.
iankarr
Dec 8 2021, 09:39 PM
The challenge is that the seal sits on top of the installed dash. If you absolutely can't take the glass out, I'd probably opt for putting the seal in AFTER the dash. Probably easier to push in on the pinch weld than to fit the dash under.
Mikey914
Dec 8 2021, 11:20 PM
The seal was designed to install without removing glass or windshield.
So, I would do it after the dash was installed. That way its installed laid flat on it.
hndyhrr
Dec 8 2021, 11:49 PM
Thank you guys!
